#2386: wxGUI: check for old vector topology format
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: critical | Milestone: 7.0.0
Component: wxGUI | Version: unspecified
Keywords: v.build.all | Platform: Unspecified
Cpu: Unspecified |
Hi, I would assume that a common problem for users switching from G6 to G7
will be a new vector topo format. When opening vector data in G7 which
were created in G6 `d.vect` fails with
WARNING: Old topology format version 5.0 is not supported by this
release. Try to rebuild topology.
It would be nice to have in wxGUI mechanism/dialog which would inform user
about that and suggest updating topology format to G7 automatically. This
tool would
1. switch to map's mapset on background
1. call `v.build` or `v.build.all`
1. switch back to current mapset and re-render display
Cpu: Unspecified |
Comment(by neteler):
Replying to [ticket:2386 martinl]:
user
Might it be better to also transfer to SQLite while we are at it?
Cpu: Unspecified |
Comment(by wenzeslaus):
> This tool would
"Switch to" and "switch back" should be done by passing `env` parameter to
the module calling function. In this way only the subprocess has the other
mapset environment. There is even no "switch back" except from deleting
the GRASS `rc` file which was passed to the subprocess. See e.g. r60376.
This is also something which could be in data catalog. However, I agree
that the point is to have it easily accessible when the problem occurs.
Cpu: Unspecified |
Comment(by mlennert):
Whatever the discussion, I don't think this is a "critical" bug. The
message is clear, the solution (v.build) is clear and so it's more of a
question of convenience.
As a first gut reaction, I would say don't do anything this fundamental
"behind the user's back". I would think that most users won't switch
wildly between grass6 and grass7 on the same data. If they do, v.build and
v.build.all exist to help them.
Resolution: | Keywords: v.build.all
Changes (by martinl):
* priority: critical => normal
Comment:
Replying to [comment:3 mlennert]:
Right, decreasing the priority.
I modified the message in r65600 to mention `v.build/v.build.all`. If no
objection I will do backport to relbr70.
Comment (by mlennert):
Replying to [comment:4 martinl]:
fundamental "behind the user's back". I would think that most users won't
switch wildly between grass6 and grass7 on the same data. If they do,
v.build and v.build.all exist to help them.
Comment (by martinl):
Replying to [comment:5 mlennert]:
no objection I will do backport to relbr70.
> +1
Replying to [comment:7 martinl]:
> Probably we could have a new addon module called `v.convert.g6` doing
conversion from GRASS 6 to GRASS 7 (v.build + v.db.connect)?
might be a nice convenience module. But just v.db.connect won't be enough
if you want to change from dbf to sqlite. The easiest would probably be
db.connect + g.copy + g.rename, or something like that.
Replying to [comment:8 mlennert]:
enough if you want to change from dbf to sqlite. The easiest would
probably be db.connect + g.copy + g.rename, or something like that.
Replying to [comment:9 martinl]:
doing conversion from GRASS 6 to GRASS 7 (v.build + v.db.connect)?
> not really, see (1)
