GDAL
August 13, 2014, 9:23am
1
#2392: GRASS GIS 6.4.5 svn r.li modules - issues with hard coded path to conf
files
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: critical | Milestone: 6.4.5
Component: Raster | Version: svn-releasebranch64
Keywords: | Platform: MSWindows 7
Cpu: x86-32 |
from the ML
http://lists.osgeo.org/pipermail/grass-dev/2014-August/070384.html
now conf-file generated in winGRASS7.1svn and the conf file stored e.g.
C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
some test:
r.li.mps --verbose map=myforest at user1
conf=C:\Users\normal\AppData\Roaming\GRASS6\movwindow7
output=myforest_mean_patch_size
ERROR: Cannot find configuration file
<C:\Users\normal\.r.li\history\C:\Users\normal\AppData\Roaming\GRASS6\movwindow7>
r.li.padrange --verbose map=myforest at user1
output=myforest_padrange
r.li.padsd --verbose map=myforest at user1
output=myforest_padsd
although the path to the conf file is given, it seems it's hard coded
where
the r.li.*-module looks for the conf file (see doubling the path in the
error message)
manually creating the .r.li-folder where the module looks for and manually
putting there the conf file, the r.li.*-module is working:
conf=C:\Users\normal\.r.li\history\movwindow7 output=myforest_padsd
r.li.padsd komplett. Raster map <myforest_padsd> created.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
August 13, 2014, 9:24am
2
#2392: winGRASS GIS 6.4.5 svn r.li modules - issues with hard coded path to conf
files
Cpu: x86-32 |
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:1> ;
GDAL
August 13, 2014, 9:28am
3
files
Keywords: wingrass, r.li | Platform: MSWindows 7
Cpu: x86-32 |
Changes (by hellik):
* keywords: => wingrass, r.li
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:2> ;
GDAL
August 15, 2014, 9:01am
4
files
Cpu: x86-32 |
Comment(by neteler):
Replying to [ticket:2392 hellik]:
To my knowledge the path should actually *not* be given (see manual page).
Does this help?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:3> ;
GDAL
August 16, 2014, 6:57pm
5
files
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:3 neteler]:
page).
I can't find this in the man page; any hint where it's noted not giving
the path?
further there are differences between winGRASS6 and winGRASS7 where the
con file is stored by the setup
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:4> ;
GDAL
August 17, 2014, 3:58pm
6
files
Cpu: x86-32 |
> from the ML
Note that the r.li directory is different in GRASS GIS 6 from than what
you tried:
# Linux
$HOME/.r.li/history/movwindow7
# Windows (untested, please test)
C:\Users\normal\AppData\Roaming\GRASS6\.r.li\history\movwindow7
... and no path in conf= when running the r.li.* modules.
See also:
http://grasswiki.osgeo.org/wiki/GRASS_configuration_files_in_home_directory
You may try to use 'g.gisenv set="DEBUG=1"' to check where r.li.* is
seeking.
Once understood, we should add a note in
grass64/raster/r.li/r.li.setup/description.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:5> ;
GDAL
August 17, 2014, 4:21pm
7
files
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:5 neteler]:
> > from the ML
e.g.
you tried:
as setup is not working at the moment in winGRASS6, I've created the conf
file in winGRASS7; and there are different places in winGRASS6 and
winGRASS7 where the conf file is stored by r.li.setup
> # Linux
in winGRASS6, it's
in winGRASS7, it's
C:\Users\normal\AppData\Roaming\GRASS7
> See also:
seeking.
as noted before, it's seeked in
yes
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:6> ;
GDAL
August 17, 2014, 5:13pm
8
files
Cpu: x86-32 |
Comment(by hellik):
Replying to [comment:6 hellik]:
> in winGRASS7, it's
it's
C:\Users\normal\AppData\Roaming\GRASS7\r.li
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:7> ;
GDAL
August 17, 2014, 6:39pm
9
files
Cpu: x86-32 |
Improved docs in G7: r61665 (r61666) and G6: r61667 (r61668). Please
check.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:8> ;
GDAL
August 18, 2014, 6:30am
10
files
Cpu: x86-32 |
It appears that the issue only comes up when using the GUI. So:
> some test:
I think that the issue in GRASS 6 is that we use the macro
G_define_standard_option(G_OPT_F_INPUT) which contains this button
generating line
Opt->gisprompt = "old_file,file,input";
For GRASS 6, we may need to replace the macro with the full definition in
each
r.li module and omit the gisprompt line to not have the GUI button.
Obviously it
becomes more difficult to find the names of the conf file.
Ideally the conf file button would open the ....\.r.li\history\ directory
but that's
AFAIK not possible. Other ideas?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2392#comment:9> ;
