[GRASS-dev] [GRASS GIS] #2401: v.distance in Long/Lat Locations
Reporter: micha | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 6.4.5
Component: Vector | Version: 6.4.4
Keywords: | Platform: Unspecified
      Cpu: Unspecified |
According to the manual, v.distance should, in a long-lat LOCATION, return
geodesic distances in meters on a sphere, rather than in degrees. This
works in the cases of point to point, and point to line.
However in the case of point to boundary the module returns distances in
degrees, and not geodesic distance.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2401&gt;
      Cpu: Unspecified |
Comment(by mlennert):
Replying to [ticket:2401 micha]:
return geodesic distances in meters on a sphere, rather than in degrees.
This works in the cases of point to point, and point to line.
I've attached a patch that solves the issue for me, but it could do with
some more testing.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2401#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
  Platform: Unspecified | Cpu: Unspecified
Changes (by mlennert):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:1 mlennert]:
in degrees, and not geodesic distance.
some more testing.
I've applied the patch in r61859 and r61860.
Closing this ticket.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2401#comment:2&gt;
Resolution: fixed | Keywords: v.distance
Changes (by neteler):
  * keywords: => v.distance
Comment:
Replying to [comment:2 mlennert]:
Are the results identical to that of GRASS GIS 7 latest SVN?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2401#comment:3&gt;
      Type: defect | Status: reopened
Resolution: | Keywords: v.distance
  * status: closed => reopened
  * resolution: fixed =>
Comment:
Replying to [comment:3 neteler]:
For point to point and point to line they seem to be equal, but there are
differences with point to area. I'll attach a file with results of the
following command:
v.distance -p from=comm_colleges to=urbanarea upload=cat,dist
col=to_cat,dist dmin=0.0001
in grass6 and grass7.
For some points (to_cats 3,7,8,12,15,23,24,25,27,32,34,43,46,48,49,52,54),
the distances are different. However, in the grass6 version they are
similar to the distances calculated in the original NC-NAD83 projection,
whereas the grass7 version gives different results.
I don't know if this is a general bug in the distance calculations in
v.distance which is corrected in the geodesic distance of grass7, or
whether the issue is in the geodesic distance calculation in grass7. I'm
suspecting the latter, but Markus M would have to look at this.
Reopening until we know for sure.
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2401#comment:4&gt;
Comment(by mmetz):
Replying to [comment:4 mlennert]:
are differences with point to area.
trunk fixed in r61943, there was an uninitialized z coordinate. There are
still two differences where G6 finds as nearest area a hole inside an area
(to_cat = null). I regard this as a bug in G6.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2401#comment:5&gt;
  * status: reopened => closed
Comment:
Replying to [comment:5 mmetz]:
are still two differences where G6 finds as nearest area a hole inside an
area (to_cat = null). I regard this as a bug in G6.
I agree, but it's not related to geodesic distances as the same problem
occurs in a projected location.
So, closing this bug and opening another for the hole as nearest area
(#2419).
Moritz
Ticket URL: <https://trac.osgeo.org/grass/ticket/2401#comment:6&gt;
