[GRASS-dev] [GRASS GIS] #2422: Functions from Segment lib have no prefix
Reporter: martinl | Owner: grass-dev@…
     Type: task | Status: new
Priority: blocker | Milestone: 7.0.0
Component: LibRaster | Version: unspecified
Keywords: segmentlib, api, prefix | Platform: Unspecified
      Cpu: Unspecified |
In contrast to other GRASS libs, Segment lib (1) doesn't use any prefix. I
would suggest to change eg.
segment_open()
to
Rast_segment_open()
Any option? Marked as blocker since it's API change.
(1) http://grass.osgeo.org/programming7/segmentlib.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:2422 martinl]:
> Rast_segment_open()
Or
Segment_segment_open()
inspired by Row Input/Output Library,
http://grass.osgeo.org/programming7/rowiolib.html
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422#comment:1&gt;
      Cpu: Unspecified |
Replying to [comment:1 martinl]:
I meant
Segment_open()
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422#comment:2&gt;
      Cpu: Unspecified |
Replying to [comment:2 martinl]:
from this point of view, we could rename function in this library to eg.
Rowio_get() -> Rast_rowio_get()
and
segment_open() -> Rast_segment_open()
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422#comment:3&gt;
      Cpu: Unspecified |
Comment(by mmetz):
The prefix used by the segment lib is "segment_".
> I would suggest to change eg.
segment_open()
> to
Segment_open()
So you mean to change the first letter of the prefix to upper case?
E.g. "Rast_segment_open" does not make sense to me because the segment
library is standalone and not part of the raster library.
Currently library functions for each library have their own prefix (that
happened also when splitting gis lib in gis lib and raster lib). This
convention makes work for developers easier and I would suggest to keep
it. Thus e.g. "Rowio_get()" is just fine, no need to mask it as a raster
lib function, it is a rowio lib function.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422#comment:4&gt;
      Cpu: Unspecified |
Replying to [comment:4 mmetz]:
> Segment_open()
yes, it's consistent with prefixes from other GRASS libs which are upper-
case. If no objection I will do this change within the next days.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422#comment:5&gt;
      Cpu: Unspecified |
Comment(by neteler):
I have updated trunk accordingly in r62324.
TODO: backport if all is ok and update Addons.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2422#comment:6&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: segmentlib, api, prefix
  Platform: Unspecified | Cpu: Unspecified
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Replying to [comment:6 neteler]:
Done in r62336 (relbr7) and r62337 (G7 Addons). Closing.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2422#comment:7&gt;
For the record: r62372 and r62373 (separate internal and external
functions)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2422#comment:8&gt;
