[GRASS-dev] [GRASS GIS] #2428: r.external to accept gdal config options
  Reporter: perrygeo | Owner: grass-dev@…
  Priority: normal | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: r.external
       CPU: x86-64 | Platform: Unspecified
Comment (by dylan):
Replying to [comment:5 glynn]:
> Replying to [comment:4 dylan]:
> > Could this same block of code be used within `r.external`? I don't
fully understand how `r.external` works, so I suppose that it is more
complicated than this.
> r.external itself just sets up the "link" between GRASS and the data
file. The actual I/O occurs in lib/raster (gdal.c, open.c, get_row.c,
close.c) when a GRASS module reads the map.
> But the data which r.external controls is per-map, while this appears to
be a global setting. What happens when a module reads multiple GDAL-linked
maps with different settings? It might make more sense to set this in
Rast_init_gdal() from an environment variable or $GISRC variable.
Thank you for the clarification Glynn. I think that a suitable
environmental or GRASS variable would be ideal. Something that isn't
widely used but *very* important when working with massive, numerous, or
massive and numerous files. I am unable to implement but happy to test and
document.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2428#comment:6&gt;
