[GRASS-dev] [GRASS GIS] #2440: remove unused elements from g.list/g.remove
Reporter: annakrat | Owner: grass-dev@…
     Type: task | Status: new
Component: LibGIS | Version: svn-releasebranch70
Keywords: elements, g.remove | Platform: All
      Cpu: Unspecified |
Half of the elements in g.remove and related modules are not used any
more. Let's remove them from GRASS7.
  * old (GRASS 5.0) vector map(s)
  * ASCII vector map(s)
  * paint icon file(s)
  * paint label file(s)
  * site list file(s)
  * 3D view parameter(s)
Please correct me if we still use some of them. Technically it's easy to
remove them, just remove a couple of lines in lib/manage/element_list
file.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440&gt;
      Cpu: Unspecified |
Comment(by martinl):
Replying to [ticket:2440 annakrat]:
agreed.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:1&gt;
      Cpu: Unspecified |
Comment(by annakrat):
Hm, we still have v.in.sites and v.in.sites.all so I would suggest to
remove them too, as well as the library (lib/sites). Does anyone know
what's the status of 'paint label file'? There are modules v.label and
d.labels so it seems that we should still support it. For the other
elements I couldn't find any module which would be using them so they can
be removed safely.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:2&gt;
      Cpu: Unspecified |
Comment(by neteler):
Replying to [comment:2 annakrat]:
Yes
> Does anyone know what's the status of 'paint label file'? There are
modules v.label and d.labels so it seems that we should still support it.
(there is also v.label.sa lurking ...)
> For the other elements I couldn't find any module which would be using
them so they can be removed safely.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:3&gt;
      Cpu: Unspecified |
I removed sites element together with the library in r62179, then I
removed paint icons in r62180 (I have no idea what it is and I haven't
found any related library) and finally I removed 3dview element, but I
kept the library itself, since it still might be useful I think. I would
appreciate if someone else could have a look at the old vector formats, I
have no idea what is the difference between them and which libraries they
use. I think we don't need any of them in GRASS7.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:4&gt;
      Cpu: Unspecified |
After some cleaning done with #2409 the list of elements is now
                raster: raster map(s)
                raster_3d: 3D raster map(s)
                vector: vector map(s)
                old_vector: old (GRASS 5.0) vector map(s)
                ascii_vector: ASCII vector map(s)
                labels: paint label file(s)
                region: region definition(s)
                group: imagery group(s)
                all: all types
Is it OK to close this ticket or is there still any remaining issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:5&gt;
      Cpu: Unspecified |
Changes (by martinl):
* cc: martinl (added)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:6&gt;
      Cpu: Unspecified |
As of r63875 it is
                all: all types
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:7&gt;
      Cpu: Unspecified |
There is still the `ascii_vector`, I have no idea what it is.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:8&gt;
Priority: blocker | Milestone: 7.0.0
      Cpu: Unspecified |
  * priority: normal => blocker
Comment:
Replying to [comment:8 annakrat]:
I also don't know. Anyone has an idea? If not I would suggest to remove it
too.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:9&gt;
      Cpu: Unspecified |
Replying to [comment:9 martinl]:
it too.
http://grass.osgeo.org/grass70/manuals/v.out.ascii.html
"If old version is requested, the output files from v.out.ascii is placed
in the $LOCATION/$MAPSET/dig_ascii/ and $LOCATION/$MAPSET/dig_att
directory."
So, it stems from GRASS GIS 4 and older. Random citation:
GRASS-Intergraph Data Conversion Guide by V Harmon - ‎1992,
http://www.dtic.mil/get-tr-doc/pdf?AD=ADA251458 (p. 14)
Less used nowadays :slight_smile:
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:10&gt;
      Cpu: Unspecified |
placed in the $LOCATION/$MAPSET/dig_ascii/ and $LOCATION/$MAPSET/dig_att
directory."
if it's only one usage I would still to vote for removing it from element
list. What do you think?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:11&gt;
      Cpu: Unspecified |
Replying to [comment:11 martinl]:
directory."
element list. What do you think?
any option?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:12&gt;
      Cpu: Unspecified |
Replying to [comment:12 martinl]:
> any option?
I removed `ascii_vector` in trunk as r64004. Any objection to backport to
`relbr70`?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:13&gt;
      Cpu: Unspecified |
Replying to [comment:13 martinl]:
> > any option?
to `relbr70`?
r64004:64005
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:14&gt;
      Cpu: Unspecified |
Replying to [comment:14 martinl]:
to `relbr70`?
> r64004:64005
done in r64104
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:15&gt;
      Cpu: Unspecified |
Currently the element list looks like:
        type Data type(s)
               options: raster,raster_3d,vector,label,region,group,all
                label: paint label file(s)
                all: all types
Is there any open issue?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:16&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords: elements, g.remove
  Platform: All | Cpu: Unspecified
Changes (by annakrat):
  * status: new => closed
  * resolution: => fixed
Comment:
Thanks! I think we can close it. The actual code for handling different
vector formats is still there, but from what I remember when I was looking
at it, it would be quite time consuming to clean it up.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2440#comment:17&gt;
