[GRASS-dev] [GRASS GIS] #2448: Fontconfig error with cairo on Windows
  Reporter: annakrat | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.0.2
Component: Display | Version: 7.0.0
Resolution: | Keywords: font, text, legend, scale bar
       CPU: Unspecified | Platform: MSWindows 8
Comment (by hellik):
Replying to [comment:37 annakrat]:
> Unfortunately built 66083 still has the same problem. The content of
fontcap seems to be the same. When I display legend, I get this in
terminal, am not sure if it was there before
> C:\Users\anna>Fontconfig error: Cannot load default config file
> GRASS_INFO_WARNING(2248,1): Unable to open font map 'C:\Program Files
(x86)\GRASS GIS 7.1.svn/fonts/.hmp': No such file or directory. Try
running 'g.mkfontcap -o'
> GRASS_INFO_END(2248,1)
I've changed
[GRASS-SVN] r66148 - grass/trunk/mswindows
[GRASS-SVN] r66149 - grass/branches/releasebranch_7_0/mswindows
Can you test the next Installer?
I've done some research, file permissions changed a lot between Windows
versions (7,8,10).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2448#comment:41&gt;
