#2476: vector digitizer crashing with _breakLineAtIntersection
Reporter: annakrat | Owner: grass-dev@…
Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: vdigit | Platform: Linux
Cpu: Unspecified |
I was able to reproduce this crash every time.
1. draw a line (just 2 points)
2. draw an area so that it intersects with the line
3. right click to confirm, crash
You would need to get areas on each side before breaking the line, but the
vector lib might only be able to build areas after the new line was
broken. I would suggest to break the line only after trying to attach
centroids.
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:1 mmetz]:
> Replying to [ticket:2476 annakrat]:
> > Crashing happens in
[http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/level_two.c#L356
level_two.c] in wxdigit.py in _addFeature. Without the line, the area
closes without problem, so maybe _breakLineAtIntersection is where
something goes wrong.
> The problem is in
[https://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/vdigit/wxdigit.py#L1772
wxdigit.py] in _addFeature: the line is broken, afterwards the digitizer
tries to get the areas for this line. But this line no longer exists
because it has been broken into new lines -> crash.
the vector lib might only be able to build areas after the new line was
centroids.
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:2 mmetz]:
centroids.
> Fixed in r63077.
Thanks, it's not crashing any more. But when I draw a line over an area,
so that it breaks, I get this error:
File "/home/anna/dev/grass/trunk1/dist.x86_64-unknown-
linux-gnu/gui/wxpython/mapwin/buffered.py", line 1248, in
MouseActions
self.OnRightUp(event)
linux-gnu/gui/wxpython/mapwin/buffered.py", line 1485, in
OnRightUp
self._onRightUp(event)
linux-gnu/gui/wxpython/vdigit/mapwindow.py", line 935, in
_onRightUp
(UserSettings.Get(group = 'vdigit', key = "category", subkey
= 'value'), )
IndexError
list index out of range
It seems to be related to the fix, list 'fids' is empty, but I couldn't
see what's wrong.
Cpu: Unspecified |
Comment(by mmetz):
Replying to [comment:3 annakrat]:
but the vector lib might only be able to build areas after the new line
was broken. I would suggest to break the line only after trying to attach
centroids.
> > Fixed in r63077.
so that it breaks, I get [another] error.
see what's wrong.
I fixed it in r63178, list 'fids' is no longer empty but can contain
invalid line ids.
