[GRASS-dev] [GRASS GIS] #2481: g.gui.iclass: cannot display analysis results because of "No graphics device selected"
device selected"
Reporter: mlennert | Owner: grass-dev@…
     Type: defect | Status: new
Component: wxGUI | Version: svn-trunk
Keywords: g.gui.iclass d.mon | Platform: Unspecified
      Cpu: Unspecified |
Using g.gui.iclass in both trunk and 70release, I do the following:
  * load group and subgroup
  * load vector training areas
  * "Run analysis"
I don't see any of the analysis maps (one per class) in the lower window,
and I get the following error messages:
Data error preparing signatures: value (388) > num of cats
(256)
La commande 'd.rast map=eau_15961.0' a échoué
Détails : No graphics device selected. Use d.mon to select
graphics device.
Data error preparing signatures: value (602) > num of cats
(256)
La commande 'd.rast map=veg_haute_15961.0' a échoué
graphics device.
Data error preparing signatures: value (394) > num of cats
(256)
La commande 'd.rast map=sol_nu_15961.0' a échoué
graphics device.
Data error preparing signatures: value (1173) > num of cats
(256)
La commande 'd.rast map=veg_basse_15961.1' a échoué
graphics device.
Data error preparing signatures: value (853) > num of cats
(256)
La commande 'd.rast map=bati_15961.1' a échoué
graphics device.
La commande 'd.rast map=pleiades_pan@PERMANENT' a échoué
graphics device.
What is really strange is that when I don't load the group and training
areas, but only display an image in the upper or lower display window, I
also get:
graphics device.
but the image is displayed.
Using i.gensig and i.maxlik I can create valid signatures and a
classification.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2481&gt;
device selected"
      Cpu: Unspecified |
Comment(by annakrat):
I can't reproduce it. It seems that No graphics device selected and Data
error preparing signatures are different problems. What kind of vector are
you loading, the one you exported before from g.gui.iclass? What kind of
data do you have in the group, I think, it can currently handle just 256
cats.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2481#comment:1&gt;
