#2489: d.out.file: Add PNG/Cairo support
Reporter: gisix | Owner: grass-dev@…
Priority: normal | Milestone: 6.4.5
Component: Display | Version: unspecified
Keywords: | Platform: All
Cpu: Unspecified |
Until now the d.out.file module works only on content from X-Monitors (x0,
x1, etc.). It would be great if this could be extended for PNG/Cairo and
possibly PS monitors. This would allow to use the module also in pure
command line - based environments
This will not change for G6 and for G7 it is an duplicate of #2595 which
might be anyway closed as wontfix because the workflow is already possible
just using:
