[GRASS-dev] [GRASS GIS] #2490: EPSG code not saved in PROJ_EPSG
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Component: Default | Version: unspecified
Keywords: | Platform: MSWindows 7
      Cpu: x86-64 |
from the ML
http://lists.osgeo.org/pipermail/grass-dev/2014-November/071807.html
> It is sometimes stored in the PROJ_INFO file.
in the recent versions of GRASS 7 it should be stored in PROJ_EPSG
file. If not than it's a bug.
tested here with
GRASS Version: 7.1.svn
GRASS SVN Revision: 62754
Erstellungsdatum: 2014-11-16
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.0
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
location wizard -> create location by epsg code (e.g. 4326)
EPSG code is not saved in PROJ_EPSG
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490&gt;
      Cpu: x86-64 |
Comment(by hellik):
Changeset 49298:
Message:
     Retain EPSG code, if available, into a metadata file.
https://trac.osgeo.org/grass/changeset/49298
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:1&gt;
Priority: major | Milestone: 7.0.0
Component: Projections/Datums | Version: svn-releasebranch70
      Cpu: x86-64 |
Changes (by neteler):
  * priority: normal => major
  * version: unspecified => svn-releasebranch70
  * component: Default => Projections/Datums
Comment:
While at it, perhaps also generate a file "PROJ_TOWGS84" since the EPSG
number does not necessarily reflect that (e.g. in Italy with multiple
TOWGS84 parameters for a single code)?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:2&gt;
Keywords: g.proj | Platform: MSWindows 7
      Cpu: x86-64 |
  * keywords: => g.proj
Comment:
Replying to [comment:1 hellik]:
> r49298: Retain EPSG code, if available, into a metadata file.
This doesn't seem to work yet or the if() conditions are not fulfilled.
It would also cover the case of creating the Location from the startup
script as well as the location wizard since in Python g.proj is called
from there:
http://grass.osgeo.org/grass71/manuals/libpython/_modules/script/core.html#create_location
Yet the bug in g.proj is to be understood:
g.proj epsg=4326 location=mylatlong
--> no PROJ_EPSG generated as expected
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:3&gt;
      Cpu: x86-64 |
Comment(by martinl):
Replying to [comment:3 neteler]:
Please could you try r64258 (trunk)?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2490#comment:4&gt;
      Cpu: x86-64 |
Replying to [comment:2 neteler]:
I think it's not needed since PROJ_INFO (which includes +towgs84) is
generated always.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:5&gt;
Reporter: hellik | Owner: martinl
     Type: defect | Status: assigned
      Cpu: x86-64 |
Changes (by martinl):
* cc: grass-dev@… (added)
  * owner: grass-dev@… => martinl
  * status: new => assigned
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:6&gt;
      Cpu: x86-64 |
Comment(by neteler):
Replying to [comment:4 martinl]:
Excellent, now it works. Please backport it.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2490#comment:7&gt;
      Cpu: x86-64 |
Replying to [comment:7 neteler]:
Done in r64273. Testing welcomed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2490#comment:8&gt;
      Cpu: x86-64 |
Time to close this ticket?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2490#comment:9&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.proj
  Platform: MSWindows 7 | Cpu: x86-64
Changes (by hellik):
  * status: assigned => closed
  * resolution: => fixed
Comment:
Replying to [comment:9 martinl]:
tested here; it works.
thanks for fixing!
Ticket URL: <http://trac.osgeo.org/grass/ticket/2490#comment:10&gt;
