#2494: d.vect.thematic broken
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Component: Display | Version: svn-releasebranch70
Keywords: d.vect.thematic, d.graph | Platform: Linux
Cpu: Unspecified |
Using the NC Example from
http://grass.osgeo.org/grass70/manuals/d.vect.thematic.html#examples
one gets:
... [all ok]...
GRASS 7.1.svn (nc_spm_08_grass7):~ > v.univar -e elev_sample col=diff
type=point
number of features with non NULL attribute: 200
number of missing attributes: 0
number of NULL attributes: 0
minimum: -26.8796
maximum: 21.2874
range: 48.167
GRASS 7.1.svn (nc_spm_08_grass7):~ > d.mon wx0
GRASS 7.1.svn (nc_spm_08_grass7):~ > d.vect.thematic -l elev_sample
column=diff type=point
Thematic map legend for column diff of map elev_sample
Value range: -26.8796 - 21.2874
Mapped by 4 intervals of 12.04175
Color(R:G:B) Value
0:0:255 -26.8796 - 21.2874
d.vect complete.
85:0:170 -26.8796 - 21.2874
d.vect complete.
170:0:85 -26.8796 - 21.2874
d.vect complete.
GRASS 7.1.svn (nc_spm_08_grass7):~ > Command 'd.graph color=black
input=/home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/23342.0'
failed
Details: Graph file
</home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/23342.0>
not found
The file names are indeed different:
ls /home/neteler/grassdata/nc_spm_08_grass7/user1/.tmp/oboe.localdomain/
23101.0.cmd 23101.0.env 23101.0.ppm.ppm
Ticket URL: <http://trac.osgeo.org/grass/ticket/2494>
