GDAL
January 5, 2015, 1:13pm
1
#2531: v.parallel: strange output
Reporter: hellik | Owner: grass-dev@…
Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: Vector | Version: svn-trunk
Keywords: parallel | Platform: MSWindows Vista
Cpu: Unspecified |
tested in the nc sample data set
v.extract input=streams@PERMANENT cats=83348 output=streams_oneline
v.parallel --verbose input=streams_oneline@user1
output=streams_oneline_parallel_test distance=100 side=both
see attached result; is this correct?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531> ;
GRASS GIS <http://grass.osgeo.org >
GDAL
January 5, 2015, 1:14pm
2
Cpu: Unspecified |
Comment(by hellik):
Replying to [ticket:2531 hellik]:
tested with
System Info
GRASS Version: 7.1.svn
GRASS SVN Revision: 63945
Erstellungsdatum: 2015-01-04
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.1
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:1> ;
GDAL
January 5, 2015, 2:29pm
3
Keywords: v.parallel | Platform: MSWindows Vista
Cpu: Unspecified |
Changes (by neteler):
* keywords: parallel => v.parallel
Comment:
IMHO this ticket is a duplicate of #90
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:2> ;
GDAL
January 5, 2015, 8:42pm
4
Priority: blocker | Milestone: 7.0.0
Cpu: Unspecified |
Changes (by hellik):
* priority: major => blocker
* milestone: 7.1.0 => 7.0.0
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:3> ;
GDAL
January 5, 2015, 8:44pm
5
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:2 neteler]:
yes it seems to be duplicate of #90 . #90 is for g6. as also v.segment is
affected by this bug, I've raised priority.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:4> ;
GDAL
January 8, 2015, 5:58pm
6
Cpu: Unspecified |
Comment(by martinl):
Replying to [comment:3 hellik]:
I wonder why it's blocker? I would say it's critical, but not the blocker.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:5> ;
GDAL
January 8, 2015, 7:44pm
7
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:5 martinl]:
blocker.
IMHO create parallel vector lines is a basic GIS function which should
work in a release of a new GRASS GIS generation. additionally it's still
an longstanding issue in g6 (see #90 ).
please feel free to downgrade.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:6> ;
GDAL
January 8, 2015, 8:10pm
8
Priority: critical | Milestone: 7.0.0
Cpu: Unspecified |
* priority: blocker => critical
Comment:
It does not impact the overall GRASS functionality, hence downgrading.
We may also consider to move it to Addons... I am not sure how important
v.parallel is.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:7> ;
GDAL
January 8, 2015, 8:46pm
9
Cpu: Unspecified |
Comment(by hellik):
Replying to [comment:7 neteler]:
> I am not sure how important v.parallel is.
IMHO creating parallel vector lines is a core functionality of a GIS
vector engine.
then, also v.segment should be moved to addons (see screenshot), as also
this module is affected by the underlying function.
my 0.02c
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:8> ;
GDAL
January 8, 2015, 8:48pm
10
Keywords: v.parallel, v.segment | Platform: MSWindows Vista
Cpu: Unspecified |
* keywords: v.parallel => v.parallel, v.segment
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:9> ;
GDAL
January 8, 2015, 8:50pm
11
#2531: v.parallel/v.segment: strange output
Cpu: Unspecified |
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:10> ;
GDAL
January 9, 2015, 11:32am
12
Cpu: Unspecified |
Comment(by mlennert):
In Vect_line_parallel2 in
[http://trac.osgeo.org/grass/browser/grass/trunk/lib/vector/Vlib/buffer2.c#L1181
lib/vector/Vlib/buffer2.c], a call to clean_parallel is commented out.
clean_parallel exists in buffer.c, not in buffer2.c. Maybe this might be a
path to a solution.
What seems to be the issue (AFAIU) is that the length of the parallel line
segments is longer than that of the original line segments, as if the
lines as projected outward. This seems to be what leads to the loops.
Don't know why such a projection is done... I'll attach a screenshot to
show what I mean.
Have you checked out the -b flag ? And possibly tried to generalize the
line before creating using v.parallel. Both might actually give you what
you are looking for ?
Ticket URL: <http://trac.osgeo.org/grass/ticket/2531#comment:11> ;
Markus,
As you are probably the one that knows the buffer code the best: do you have any idea about this ?
Moritz
-------- Forwarded Message --------
Subject: Re: [GRASS GIS] #2531: v.parallel/v.segment: strange output
Date: Fri, 09 Jan 2015 11:32:27 -0000
Reply-To: grass-dev@lists.osgeo.org
To: undisclosed-recipients:;
Cpu: Unspecified |
path to a solution.
show what I mean.
