[GRASS-dev] [GRASS GIS] #2596: v.rast.stats not working on GRASS 6.4.4
Reporter: micha | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone:
Component: Shell Scripts | Version: 6.4.4
Keywords: | Platform: Linux
      Cpu: Unspecified |
Using v.rast.stats in GRASS 6.4.4 I am finding two problems.
The new script uses 'BEGIN TRANSACTION', but if the backend database is
still dbf, transactions are not supported, and the process fails.
If I switch to sqlite tables, the process runs, but I am getting NULL
values in all the univariate stats columns.
I tried to replace the v.rast.stats shell script with the script from the
older 6.4.2 tarball, and it works fine.
Micha
Ticket URL: <http://trac.osgeo.org/grass/ticket/2596&gt;
      Type: defect | Status: closed
  Priority: major | Milestone: 6.4.5
Resolution: duplicate | Keywords: v.rast.stats
  Platform: Linux | Cpu: Unspecified
Changes (by neteler):
  * keywords: => v.rast.stats
  * status: new => closed
  * resolution: => duplicate
  * milestone: => 6.4.5
Comment:
This is a duplicate of #2457 which I hopefully solved.
You may try the updated script from here:
https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4/scripts/v.rast.stats/v.rast.stats
It will be part of the upcoming GRASS GIS 6.4.5.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2596#comment:1&gt;
