#2607: Python shell hint results in OSError error(None): None
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone:
Component: wxGUI | Version: 7.0.0
Keywords: | Platform: MSWindows Vista
Cpu: Unspecified |
In Python shell type in:
from grass.pygrass.modules.shortcuts import raster as r
r.
and observe how it gets filled with gazzilion of error messages: "OSError
error(None): None"
Due to this error, it is impossible to use Python shell, as it is trying
to execute error message as a command instead of just providing it as an
"error text that messes up CLI".
Keywords: | Platform: All
Cpu: Unspecified |
Comment(by annakrat):
Replying to [comment:1 marisn]:
> Same happens with 7.1 SVN on GNU/Linux, still error message is a bit
different: "OSError error(2): No such file or directory"
It works fine for me using Ubuntu. Does it happen only in the Python shell
in wxGUI?
Cpu: Unspecified |
Comment(by zarch):
Replying to [comment:2 annakrat]:
shell in wxGUI?
I have the same error also in ipython shell:
In [2]: r.OSError error(2): No such file or directory
Display all 187 possibilities? (y or n)
r.basin_fill
r.buffer
