[GRASS-dev] [GRASS GIS] #2627: v.out.postgis uses wrong database name or port
  Reporter: wenzeslaus | Owner: grass-dev@…
      Type: defect | Status: new
  Priority: normal | Milestone: 7.2.0
Component: Default | Version: svn-trunk
Resolution: | Keywords: PostgreSQL, postgres, PostGIS
Comment (by mlennert):
The handling of host and port info have changed (use db.login instead of
db.connect for that info). Could you test whether this is still an issue
for you in 7.2 ?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2627#comment:2&gt;
