[GRASS-dev] [GRASS GIS] #2634: 'utf8' codec can't decode byte 0xf6 in position 8: invalid start byte
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.1.0
Component: Default | Version: svn-trunk
Keywords: utf, wxgui | Platform: MSWindows 7
      Cpu: x86-32 |
taken from the ML
http://lists.osgeo.org/pipermail/grass-dev/2015-March/074529.html
GRASS Version: 7.1.svn
GRASS SVN revision: 64858
Build date: 2015-03-15
Build platform: i686-pc-mingw32
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-7-6.1.7601-SP1 (OSGeo4W)
a ms windows error message window:
<http://osgeo-
org.1560.x6.nabble.com/file/n5193488/utf_codec_error_15032015_232313.png>
pops up when invoking e.g.
d.vect
r.slope.aspect
and following error message:
   File "C:\OSGEO4~2\apps\grass\grass-7.1.svn\gui\wxpython\gu
i_core\forms.py", line 2054, in OnUpdateDialog
self.parent.updateValuesHook()
i_core\forms.py", line 628, in updateValuesHook
self.SetStatusText('
'.join(self.notebookpanel.createCmd(ignoreErrors = True)))
TypeError
http://lists.osgeo.org/pipermail/grass-dev/2015-March/074540.html
interesting:
_no_ problems with commands like e.g.:
g.region
g.mapset
g.access
g.gisenv
g.extension
r.slope.aspect
d.vect
r.watershed
r.neigbhours
v.parallel
also tested on another machine:
System Info
GRASS SVN revision: 64889
Build date: 2015-03-21
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
the same error
Ticket URL: <http://trac.osgeo.org/grass/ticket/2634&gt;
  Priority: critical | Milestone: 7.1.0
Resolution: | Keywords: utf, wxgui
       CPU: x86-32 | Platform: MSWindows 7
Changes (by hellik):
* priority: major => critical
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:1&gt;
Comment (by hellik):
Replying to [ticket:2634 hellik]:
> taken from the ML
> GDAL: 1.11.2
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> <http://osgeo-
> d.vect
> r.slope.aspect
> TypeError
> interesting:
> g.region
> g.mapset
> g.access
> g.gisenv
> g.extension
> r.slope.aspect
> d.vect
> r.watershed
> r.neigbhours
> v.parallel
> System Info
> GDAL: 1.11.2
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> the same error
still valid for
GRASS SVN revision: 65460
Build date: 2015-06-14
GDAL: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
makes winGRASS trunk quite unusable ... not there in winGRASS7.0.x ....
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:2&gt;
Replying to [comment:2 hellik]:
tested on different german winVista/win7/win8-boxes ...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:3&gt;
  Priority: critical | Milestone: 7.0.1
* milestone: 7.1.0 => 7.0.1
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:4&gt;
it's also now in the 7.0.1RC1, tested in the NC sample dataset
System Info
GRASS Version: 7.0.1RC1
GRASS SVN Revision: 65472
Erstellungsdatum: 2015-06-15
Build Platform: i686-pc-mingw32
GDAL/OGR: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
choosing d.rast from the wxgui
a MS error box pops up with
followed by this message in the wxgui
   File "C:\OSGEO4~2\apps\grass\grass-7.0.1RC1\gui\wxpython\g
ui_core\forms.py", line 2023, in OnUpdateDialog
ui_core\forms.py", line 628, in updateValuesHook
TypeError
as mentioned in the original ticket above, e.g. g.region works without any
problem
any ideas?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:5&gt;
Replying to [comment:5 hellik]:
> System Info
> GDAL/OGR: 1.11.2
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
> TypeError
any problem
> any ideas?
language is set following:
GUI preferences -> language -> system
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:6&gt;
Replying to [comment:6 hellik]:
ok, I switched the language to englisch:
GUI preferences -> language -> en
this error disappears.
maybe some error in the translation?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:7&gt;
Replying to [comment:7 hellik]:
system language is german
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:8&gt;
Comment (by marisn):
Haven't tested, but it seems like the opposite. A string is translated but
some python code expects it to be an ascii string. There have been similar
issues already reported (see #2617 for longer discussion). Traceback
indicates use of str method on unicode object in 'gui_core\forms.py' file.
wxgui is full of such issues and in many places it is unknown if adding
just a u' ' would not introduce problems elsewhere :frowning: Backporting r64834
could help in some cases but an overhaul of any string processing in wxgui
is required with strict rules (that need to be created).
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:9&gt;
Comment (by martinl):
Replying to [comment:9 marisn]:
adding just a u' ' would not introduce problems elsewhere :frowning: Backporting
r64834 could help in some cases but an overhaul of any string processing
in wxgui is required with strict rules (that need to be created).
it's already done in r65462
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:10&gt;
Replying to [comment:10 martinl]:
Helmut, could you please test current 7.0.1svn if it still works (1)?
(1) http://wingrass.fsv.cvut.cz/grass70/
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:11&gt;
Replying to [comment:11 martinl]:
Backporting r64834 could help in some cases but an overhaul of any string
processing in wxgui is required with strict rules (that need to be
created).
tested with
GDAL/OGR: 1.11.2
PROJ.4: 4.8.0
GEOS: 3.4.2
SQLite: 3.7.17
Python: 2.7.4
wxPython: 2.8.12.1
manually and locally reverted r65462 => error disappears
r.slope.aspect
d.vect
r.watershed
r.neigbhours
v.parallel
all these modules are working without the reported error!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:12&gt;
Replying to [comment:12 hellik]:
created).
> tested with
> GDAL/OGR: 1.11.2
> PROJ.4: 4.8.0
> GEOS: 3.4.2
> SQLite: 3.7.17
> Python: 2.7.4
> wxPython: 2.8.12.1
tested in german locale!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:13&gt;
done in r65527.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:14&gt;
Replying to [comment:14 martinl]:
> done in r65527.
I have reverted this commit also in r65528.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:15&gt;
> done in r65527.
Please could you try the next build, no. >= 63 (1)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:16&gt;
Comment (by annakrat):
Have anyone tried to investigate where the utf8 error comes from? Perhaps
r65462 is not the problem. I agree with reverting it for the release, but
it should stay in trunk for more investigation.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:17&gt;
Replying to [comment:17 annakrat]:
Perhaps r65462 is not the problem. I agree with reverting it for the
release, but it should stay in trunk for more investigation.
g.gisenv set=DEBUG=3
C:\>r.slope.aspect
D1/3: G_set_program_name(): r.slope.aspect
D2/3: G_file_name(): path = C:\grassdata/gbifwgs84/chechdb
D3/3: G_recreate_command()
D3/3: win_spawn: args = C:\windows\system32\cmd.exe /c
"C:\OSGEO4~2\bin\python.e
xe C:\OSGEO4~2\apps\grass\grass-7.1.svn/gui/wxpython/gui_core/forms.py
r.slope.a
spect"
D1/3: G_set_program_name(): g.gisenv
D3/3: G_option_to_separator(): key = separator -> sep = '
D1/3: grass.script.core.start_command(): g.gisenv -n
   File
"C:\OSGEO4~2\apps\grass\grass-7.1.svn/gui/wxpython/gui_core/forms.py", li
ne 2545, in <module>
     Debug.msg(1, "forms.py opening form for: %s" %
task.get_cmd(ignoreErrors=Tru
e))
   File
"C:\OSGEO4~2\apps\grass\grass-7.1.svn\etc\python\grass\script\task.py", l
ine 235, in get_cmd
     cmd += [('%s=%s' % (p['name'], _('<required>'))).decode('utf-8')]
   File "C:\OSGEO4~2\apps\Python27\lib\encodings\utf_8.py", line 16, in
decode
     return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode byte 0xf6 in position 14:
invalid
start byte
C:\>
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:18&gt;
Please try this (with r64834 in place):
#!diff
Index: task.py
--- task.py (revision 65450)
+++ task.py (working copy)
@@ -232,7 +232,7 @@
                  if p.get('default', '') != '':
                      cmd += ['%s=%s' % (p['name'], p['default'])]
                  elif ignoreErrors and not suppress_required and not
ignoreRequired:
- cmd += [('%s=%s' % (p['name'],
+ cmd += ['%s=%s' % (p['name'], _('<required>'))]
              elif p.get('value', '') == '' and p.get('default', '') != ''
and not ignoreDefault:
              elif p.get('value', '') != '' and \
This was introduced in r61704 and seems to be not needed with r64834.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2634#comment:19&gt;
