#2670: v.voronoi skeleton: nonsense result with many adjacent polygons
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.8.0
Component: Default | Version: svn-trunk
Resolution: | Keywords:
Comment (by mmetz):
Replying to [comment:9 martinl]:
> With GRASS 7.6.0 I am getting
> v.voronoi -s census_wake2000 out=census_skel
> Reading features...
> ERROR: Found 0 vertices in <census_wake2000@PERMANENT>, but at least 2
are
> needed
From the manual: "The bounds of the output map are limited by the current
region (see g.region)."
Then you get no error but nonsense results.
Replying to [comment:10 mlennert]:
> Moving this on to milestone 7.8, but not sure if this is really fixable.
> MarkusM, should this be a no fix ?
Not sure, v.voronoi generally suffers from numerical instability.
Previously, I could improve it a bit, but it's not perfect, but I have one
more idea (maybe in the next few weeks I find time to try this idea: scale
coordinates to region center).
Furtheron, something seems to be conceptually wrong with the skeletons for
adjacent areas, that should be fixable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2670#comment:11>
