#2675: r.in.gdal -e should set region to newly imported map
Reporter: volcan01010 | Owner: grass-dev@…
Priority: minor | Milestone: 7.0.1
Component: Raster | Version: 7.0.0
Keywords: r.in.gdal region | CPU: Unspecified
Platform: Linux |
When running r.in.gdal with the -e flag (to update the region from the
imported raster extents), the command finishes by setting the region to
the default setting (even if that was not the previous setting).
It may be preferable for it to set the region to match the newly imported
map, so that follow up operations e.g. r.composite are run with the
correct settings.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2675>
