[GRASS-dev] [GRASS GIS] #2782: modeler problems with variable
Reporter: lucadelu | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.2
Component: wxGUI | Version: unspecified
Keywords: modeler | CPU: Unspecified
Platform: Unspecified |
Using the modeler I found two problems with names for new map when command
are loop and it use ''%map'' variable:
- using something like %map.new in the python tab the ''.new'' is not
recognized and I get an error during validation
- using something like %map.%new where new is defined as variable in the
python code there are to many quotes after the name
You can see the problem in the attached png and try it using the gxm file
and north carolina landsat dataset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2782&gt;
Resolution: | Keywords: modeler
Changes (by lucadelu):
* Attachment "problems.gxm" added.
* Attachment "problems.png" added.
  Priority: normal | Milestone: 7.0.3
Comment (by martinl):
Both issue should be fixed in r67470 (trunk). Please test. When confirmed
I will backport it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2782#comment:2&gt;
  Priority: normal | Milestone: 7.0.4
Comment (by neteler):
If tested, please backport r67470.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2782#comment:5&gt;
Comment (by lucadelu):
Yes, it works, please backport
Ticket URL: <https://trac.osgeo.org/grass/ticket/2782#comment:6&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: modeler
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Done in r67835. Closing, feel free to reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2782#comment:7&gt;
