[GRASS-dev] [GRASS GIS] #2785: pygrass util set_path bug
Reporter: krejcmat | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: PyGRASS | Version: svn-trunk
Keywords: path | CPU: x86-64
Platform: Linux |
The current code doesn't count with parameters of the function
"from grass.pygrass.utils import set_path". Diff[1] is below.
thanks
Matej
[1]
Index: lib/python/pygrass/utils.py
--- lib/python/pygrass/utils.py (revision 66629)
+++ lib/python/pygrass/utils.py (working copy)
@@ -313,7 +313,7 @@
      pathlib = os.path.join(path, dirname)
      if os.path.exists(pathlib):
          # we are running the script from the script directory
- sys.path.append(os.path.abspath(path))
+ sys.path.append(os.path.abspath(pathlib))
      else:
          # running from GRASS GIS session
          path = get_lib_path(modulename, dirname)
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785&gt;
  Priority: normal | Milestone: 7.0.1
Resolution: | Keywords: path
       CPU: x86-64 | Platform: Linux
Changes (by martinl):
* milestone: => 7.0.1
Old description:
thanks
Matej
[1]
@@ -313,7 +313,7 @@
     else:
New description:
thanks
Matej
[1]
@@ -313,7 +313,7 @@
      else:
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785#comment:1&gt;
  Priority: normal | Milestone: 7.0.2
* milestone: 7.0.1 => 7.0.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785#comment:2&gt;
Comment (by martinl):
Please attach diff as the attachment.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785#comment:3&gt;
Description changed by martinl:
Old description:
thanks
Matej
[1]
@@ -313,7 +313,7 @@
     else:
New description:
"from grass.pygrass.utils import set_path". Diff is below:
thanks
Matej
[1]
@@ -313,7 +313,7 @@
      else:
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785#comment:4&gt;
Changes (by krejcmat):
* Attachment "set_path.diff" added.
diff with fixed bug
      Type: defect | Status: closed
Resolution: fixed | Keywords: path
* status: new => closed
* resolution: => fixed
Comment:
Done in r66637, backported to relbr70 as r66638
Ticket URL: <https://trac.osgeo.org/grass/ticket/2785#comment:5&gt;
