#2799: wxGUI: display toolbar size too large
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: svn-releasebranch70
Keywords: wxGUI | CPU: Unspecified
Platform: Unspecified |
On my laptop, with a 1366x768 pixel screen, I am not able to see the
entire
display toolbar without overlapping the window with that of the map layer
manager.
Attached a screenshot.
Proposed solution: split the already dockable toolbar into two toolbars so
that the user can stack both parts on top of each other on smaller
screens.
Resolution: | Keywords: wxGUI
Comment (by wenzeslaus):
Can you please take a screenshot with the 2D view/3D view/... selection
active, i.e. with all the items visible? It seems that most of the space
in the toolbar is taken by whitespace in that select box. For me
(wxPython: 3.0.1.1) the select box is much much smaller and with
digitizers, I don't see all the text when the mode is active. It also
seems that the padding around the buttons is much bigger on your machine.
Comment (by martinl):
Replying to [ticket:2799 neteler]:
so
screens.
the toolbar is too long, your proposal make sense to me.
I think that splitting it into two parts would make it quite uncomfortable
when moving the toolbar(s) out of the windows (you would have to fiddle
with two instead of one). The handle at the beginning of the toolbar would
make the whole toolbar longer. Putting into two rows is not really an
option for small (all?) screens.
In r67699 I have removed the separators which I think were not necessary.
This makes it one button shorter for me (which is not enough).
I suggest to remove ''Erase display'' and ''Print display'' buttons. I
don't think they are that useful. Opinions?
Comparing to 70 branch, trunk has one more button which is ''Select vector
feature(s)''. We also added zoom to region recently. Both should be
definitively there but we should keep in mind that we've already hit the
limit.
The biggest issue probably is the combo box with the different modes. I
don't know why it is so big on the screenshot from Markus. There are no
long entries in it in 70 (''2D view'', ''3D view'', ''Digitize''). For me
it is much smaller (even in trunk where there is ''Vector digitizer'' and
''Vector digitizer'') but when the window is too small and the whole combo
box wouldn't fit there, the combo box just disappears and there is an
empty space instead. These both issues might be related to wxPython or the
specific platform. However, the issue probably is that this combo box
doesn't work well in a toolbar. Further research is needed to determine if
there is some good replacement. For example, the normal toolbar buttons
are grouped under one automatically for me when the window is really small
(the string we use as internal label is shown as menu item).
In r67700 I removed some toolbar separators in Layer Manager. Making lmgr
smaller might be also a way. There is probably a reason why there is so
many separate toolbars in the lmgr, but if we merge them, we would save
some horizontal space (the toolbar handles look ugly anyway on many
platforms: Win, Mac, Lubuntu).
However, there is some minimal size set now for lmgr. I assume that it is
because of issue with hidden menu items on platforms which don't support
some arrow or something to deal with long menus (#1742). But perhaps it is
not a big issue anymore when we have quite usable ''Search modules'' tab.
Replying to [comment:7 wenzeslaus]:
+1
vector feature(s)''. We also added zoom to region recently. Both should be
limit.
Although, I do find it an improvement in user experience, I wouldn't have
any objection to move 'zoom to region' back into the zoom menu where it
used to be if that is necessary.
r67699 (no separators in Map Display toolbar) backported in r67698
together with r67700.
With wxPython 3.0.2.0 on Ubuntu 15.10 with Unity, all the toolbar objects
disappear one by one when the toolbar is too small for the whole object to
fit. However, the standard toolbar buttons are still accessible through an
arrow/triangle at the end of the toolbar in case they are hidden. The look
is not really good but all the functionality is accessible including the
buttons with submenu (e.g. ''Various zoom options'') and buttons which
switch with each other (e.g. ''Digitize area/boundary/centroid'').
However, this does not work for the other widgets like the combobox/choice
which is used to switch the Map Display modes.
Replying to [comment:9 mlennert]:
> +1
r65774 and r67826 removed ''Display map'', ''Erase display'', and ''Print
display'' buttons. The trunk toolbar is now 2 buttons shorter than the
release branch toolbar.
Now, there is no way to invoke the ''Print display'' functionality, but I
left the function there for now.
Replying to [comment:10 wenzeslaus]:
objects disappear one by one when the toolbar is too small for the whole
object to fit. However, the standard toolbar buttons are still accessible
through an arrow/triangle at the end of the toolbar in case they are
hidden. The look is not really good but all the functionality is
accessible including the buttons with submenu (e.g. ''Various zoom
options'') and buttons which switch with each other (e.g. ''Digitize
area/boundary/centroid''). However, this does not work for the other
widgets like the combobox/choice which is used to switch the Map Display
modes.
Under Fedora 23 (wxPython 3.0.2.0), though I can shrink the toolbar in Map
Display and I see the behaviour you describe, I can no longer shrink the
Map display window and therefore, it still overlaps with layer manager
even if it is also shrunk until limit size allowed. Same thing happens in
trunk (r67847) and release branch (r67848).
My screen is also 1366x768. I attach a png file.
Replying to [comment:12 veroandreo]:
> Under Fedora 23 (wxPython 3.0.2.0)...I can no longer shrink the Map
display window and therefore, it still overlaps with layer manager even if
Since when you can't do it? I don't know about any changes in release
branch in relation to that, so it would seem that it might be related to
some wxPython changes. Also many of these problems are coming from
wxPython itself or its interaction with underlying library, so what you
can try is to download the [http://www.wxpython.org/download.php wxPython
demo], find same widget there and if it has the bad behavior, report the
issue on the [http://trac.wxwidgets.org wxWidgets Trac] (component
wxPython).
It doesn't seem that Map Display is setting minimal size (`SetMinSize`)
unlike for example Layer Manager window. I actually can make the window
"one pixel" big with the same wxPython (wxPython: 3.0.2.0). I guess the
question also is if you can shrink the other windows in that particular
direction.
Replying to [comment:13 wenzeslaus]:
wxPython).
direction.
The issue prevails here in 72 (r69220) and trunk (r69219) under fedora24.
I cannot shrink map display window, nor the window for d.vect, for
example. I am able to shrink in any direction the window of g.gui.tplot,
though. No idea
