[GRASS-dev] [GRASS GIS] #2824: g.gui.timeline throws exception when trying to display temporal dataset.
Reporter: pmav99 | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: wxGUI | Version: 7.0.1
Keywords: g.gui.timeline | CPU: Unspecified
Platform: Unspecified |
I was trying to follow the temporal workshop and I am getting the
following exception:
GRASS 7.0.1 (NC_spm_temporal_workshop):~/repo > g.gui.timeline tempmean
   File "/usr/lib/grass70/scripts/g.gui.timeline", line 64, in <module>
     main()
   File "/usr/lib/grass70/scripts/g.gui.timeline", line 57, in main
     frame.SetDatasets(datasets)
   File "/usr/lib/grass70/gui/wxpython/timeline/frame.py", line 444, in
SetDatasets
     self._redraw()
   File "/usr/lib/grass70/gui/wxpython/timeline/frame.py", line 364, in
_redraw
     self._draw2dFigure()
   File "/usr/lib/grass70/gui/wxpython/timeline/frame.py", line 316, in
_draw2dFigure
     facecolors=color, alpha=ALPHA))
   File "/home/grassuser/venv/local/lib/python2.7/site-
packages/matplotlib/__init__.py", line 1811, in inner
     return func(ax, *args, **kwargs)
packages/matplotlib/axes/_axes.py", line 2339, in broken_barh
     xranges = self.convert_xunits(xranges)
packages/matplotlib/artist.py", line 189, in convert_xunits
     return ax.xaxis.convert_units(x)
packages/matplotlib/axis.py", line 1442, in convert_units
     ret = self.converter.convert(x, self.units, self)
packages/matplotlib/dates.py", line 1553, in convert
     return date2num(value)
packages/matplotlib/dates.py", line 380, in date2num
     return _to_ordinalf_np_vectorized(d)
packages/numpy/lib/function_base.py", line 1573, in __call__
     return self._vectorize_call(func=func, args=vargs)
packages/numpy/lib/function_base.py", line 1633, in _vectorize_call
     ufunc, otypes = self._get_ufunc_and_otypes(func=func, args=args)
packages/numpy/lib/function_base.py", line 1597, in _get_ufunc_and_otypes
     outputs = func(*inputs)
packages/matplotlib/dates.py", line 221, in _to_ordinalf
     base = float(dt.toordinal())
AttributeError: 'numpy.float64' object has no attribute 'toordinal'
workshop link: http://ncsu-osgeorel.github.io/grass-temporal-workshop/
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824&gt;
Resolution: | Keywords: g.gui.timeline
Comment (by wenzeslaus):
[http://stackoverflow.com/questions/32788554/plotting-with-date-times-and-
matplotlib Comment on a SO answer says]:
> It sounds like you're calling `date2num` on a `float`. `date2num`
expects `datetime` objects. ...appears to already be in exactly the format
that `date2num` would be converting it do. Replace `date2num(time)` with
just `time`...
But I'm not sure if this applies in this case. That one was related to
some particular NetCDF file.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:1&gt;
I'm not getting this error when I try on the full NC sample dataset:
g.region raster=elev_lid792_1m res=4
r.sun.hourly elevation=elev_lid792_1m glob_rad_basename=rad \
   start_time=5 end_time=10 year=2005 day=255 time_step=1 -t
g.gui.timeline rad
(year=2005 is there to create dataset with absolute time.)
Tested on 64bit Linux machine. My versions of numpy and matplotlib are the
following:
>>> import numpy
>>> numpy.__version__
'1.8.2'
>>> import matplotlib
>>> matplotlib.__version__
'1.4.2'
Please run python in GRASS session and get the versions as well. Check
also that the Python version is 2.7.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:2&gt;
Comment (by annakrat):
Something changed in 1.5 matplotlib version. I tried to fix it in r67069.
It would be great if we can get it tested with more versions of
matplotlib.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:3&gt;
Comment (by veroandreo):
g.gui.timeline works without errors for me with:
>>> import numpy
>>> numpy.__version__
'1.9.2'
>>> import matplotlib
'1.4.3'
Python is 2.7.10 and I'm using grass 7.1 r67001
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:4&gt;
Waiting for testing to get it backported.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:5&gt;
Comment (by neteler):
Just tried trunk, with the original dataset:
Invalid input data
Reason: Space time dataset <tempmean> not found.
   File "/home/neteler/software/grass71/dist.x86_64-pc-linux-
gnu/gui/wxpython/timeline/frame.py", line 444, in SetDatasets
     datasets = self._checkDatasets(datasets)
gnu/gui/wxpython/timeline/frame.py", line 414, in _checkDatasets
     raise GException(errorMsg)
GException: Space time dataset <tempmean> not found.
Maybe a try - except could be still added for beautification.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:6&gt;
Replying to [comment:6 neteler]:
> Invalid input data
There is already try except, do you want to hide the traceback? But this
is unrelated to the problem, is it working if you specify a correct
dataset?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:7&gt;
Replying to [comment:7 annakrat]:
Yes.
> But this is unrelated to the problem, is it working if you specify a
correct dataset?
Ok, if the dataset was created but is yet empty (simulating a new user or
so here):
GRASS 7.1.svn (NC_spm_temporal_workshop):~ > g.gui.timeline tempmean
gnu/scripts/g.gui.timeline", line 64, in <module>
     main()
gnu/scripts/g.gui.timeline", line 57, in main
gnu/gui/wxpython/timeline/frame.py", line 452, in SetDatasets
     self._redraw()
gnu/gui/wxpython/timeline/frame.py", line 366, in _redraw
gnu/gui/wxpython/timeline/frame.py", line 322, in _draw2dFigure
     self.fig.autofmt_xdate()
   File "/usr/lib64/python2.7/site-packages/matplotlib/figure.py", line
447, in autofmt_xdate
     for label in self.axes[0].get_xticklabels():
   File "/usr/lib64/python2.7/site-packages/matplotlib/axes/_base.py", line
2661, in get_xticklabels
     which=which))
   File "/usr/lib64/python2.7/site-packages/matplotlib/axis.py", line 1214,
in get_ticklabels
     return self.get_majorticklabels()
   File "/usr/lib64/python2.7/site-packages/matplotlib/axis.py", line 1168,
in get_majorticklabels
     ticks = self.get_major_ticks()
   File "/usr/lib64/python2.7/site-packages/matplotlib/axis.py", line 1297,
in get_major_ticks
     numticks = len(self.get_major_locator()())
   File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 866,
in __call__
     self.refresh()
   File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 883,
in refresh
     dmin, dmax = self.viewlim_to_dt()
   File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 627,
in viewlim_to_dt
     return num2date(vmin, self.tz), num2date(vmax, self.tz)
   File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 345,
in num2date
     return _from_ordinalf(x, tz)
   File "/usr/lib64/python2.7/site-packages/matplotlib/dates.py", line 225,
in _from_ordinalf
     dt = datetime.datetime.fromordinal(ix)
ValueError: ordinal must be >= 1
... sure, a user error but perhaps worthwhile catching it, too.
Then I filled "tempmean" with content, i.e. I used t.register. Now
works fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:8&gt;
Replying to [comment:8 neteler]:
> works fine.
Just for the record, your version of matplotlib is?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:9&gt;
Replying to [comment:9 annakrat]:
It is
python-matplotlib-wx-1.4.3-6.fc23.x86_64
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:10&gt;
> Yes.
Done in r67324.
or so here):
Done in r67325. It's probably safe but if you could test it before
backporitng, that would be helpful.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2824#comment:11&gt;
Tested in trunk, now all good.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:12&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: g.gui.timeline
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
All backported in r67346. Nobody except for me tested the change with new
matplotlib version, so please reopen if needed.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:13&gt;
Comment (by pmav99):
Sorry for not providing feedback earlier but i was working on non-GRASS
related things. I just tested `7.0.3svn (r67414)` with both `matplotlib
1.3.1` (from ubuntu repositories) and `matplotlib 1.5.0` (from pypi) and
everything seems to work fine.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:14&gt;
Replying to [comment:14 pmav99]:
Thanks! I wonder if g.gui.tplot needs to be fixed as well? Have you tried
that?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:15&gt;
Replying to [comment:15 annakrat]:
tried that?
Just tried `g.gui.tplot` and it works fine with both `matplotlib==1.3.1`
and `matplotlib==1.5.0`
Ticket URL: <https://trac.osgeo.org/grass/ticket/2824#comment:16&gt;
