[GRASS-dev] [GRASS GIS] #2865: Error when installing r.modis add-on and warning when starting grass
Reporter: veroandreo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.3
Component: Addons | Version: svn-trunk
Keywords: r.modis | CPU: x86-64
Platform: Linux |
Hi
I get the following error when installing the add-on r.modis.
GRASS 7.1.svn (latlong_wgs84):~ > g.extension r.modis
Fetching <r.modis> from GRASS GIS Addons repository (be patient)...
Compiling...
   File
"/tmp/grass7-veroandreo-3549/tmpMJRoMB/r.modis/scripts/r.modis.download",
line 94, in <module>
     from rmodislib import product
ImportError: No module named rmodislib
make[1]: *** [r.modis.download.tmp.html] Error 1
   File
"/tmp/grass7-veroandreo-3549/tmpMJRoMB/r.modis/scripts/r.modis.import",
line 100, in <module>
     from rmodislib import resampling, product, projection, get_proj
make[1]: *** [r.modis.import.tmp.html] Error 1
Installing...
/usr/bin/install: cannot stat
‘/tmp/grass7-veroandreo-3549/tmpMJRoMB/r.modis/docs/html/r.modis.download.html’:
No such file or directory
make[1]: *** [install] Error 1
‘/tmp/grass7-veroandreo-3549/tmpMJRoMB/r.modis/docs/html/r.modis.import.html’:
Updating addons metadata file...
Installation of <r.modis> successfully finished
It seems to work fine though... I can load both r.modis.download and
r.modis.import GUIs and do what I need to do. But, every time I start
grass again, I get:
GRASS 7.1.svn (latlong_wgs84):~ > r.modis: Unable to fetch interface
description for command 'r.modis'.
Details: [Errno 2] No such file or directory
WARNING: Some addons failed when loading. Please consider to update your
addons by running 'g.extension.all -f'.
I fetch add-ons and all fine, but when re-start grass again... same
WARNING as before. If I start grass without the GUI, there's no WARNING.
If I remove r.modis add-on, I no longer get that error, of course. Don't
know if both errors are related to the same thing or not. AFAIK, the same
happens with the add-on r.green. Something is not recognized somehow.
I have some other add-ons installed (r.hants, for example), but no warning
regarding any of them, just r.modis.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865&gt;
Resolution: | Keywords: r.modis
       CPU: x86-64 | Platform: Linux
Comment (by martinl):
Replying to [ticket:2865 veroandreo]:
I cannot reproduce this error in trunk. Please try to update your
installation first.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:1&gt;
Comment (by veroandreo):
Replying to [comment:1 martinl]:
installation first.
Hi, Martin. I just updated to r67570 and tried again. Exactly the same
behavior.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:2&gt;
Hi again :slight_smile:
I was exchanging emails with Luca regarding this issue, and he said he
tried to fix the problem reported but (quoting him, hope he doesn't mind)
"it seems bigger than expected. There is no bug in r.modis but the problem
is in lib/python/script/task.py because it doesn't find r.modis (but the
problem is there also with r.green)."
Maybe this helps?
Thanks a lot!
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:3&gt;
Replying to [comment:3 veroandreo]:
here you speak about
I guess. It's harmless error which you can ignore. Yes of course it should
be fixed. GUI is just trying to parse all addons and it's expecting that
addon name is same with command (which is not true in the case of r.modis
or r.green).
The real problem is compilation error which I was not able to reproduce.
Martin
Ticket URL: <http://trac.osgeo.org/grass/ticket/2865#comment:4&gt;
Replying to [comment:4 martinl]:
your
yes
should be fixed. GUI is just trying to parse all addons and it's expecting
that addon name is same with command (which is not true in the case of
r.modis or r.green).
I understand, yes. As they are "groups" of addons, it should try to find
all r.modis.* or r.green.* and not only r.modis/r.green.
Martin
I'm using r67612 now, tested again and the same error when installing. Is
there anything I can do so you have more information to reproduce this
error yourself? Or any other information I could report and that's
relevant for this issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:5&gt;
  Priority: normal | Milestone: 7.0.4
Comment (by Veroandreo):
Just an update:
Somewhere in the way between r67891 (the last ticket I opened) and r67965
that I'm using now, the warning when opening grass dissapeared but the
other issue (the serious one) remains. I tried removing r.modis and
installing back and here's the output:
Compiling...
   File
"/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/scripts/r.modis.download",
   File
"/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/scripts/r.modis.import",
Installing...
‘/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/docs/html/r.modis.download.html’:
‘/tmp/grass7-veroandreo-20256/tmp8pdvRv/r.modis/docs/html/r.modis.import.html’:
same as originally reported... the effect is that when I call modules'
user interfaces they do not contain the "Manual page" (See attached .png).
I do get help if I use nameofmodule --h
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:8&gt;
Changes (by Veroandreo):
* Attachment "r_modis_no_manual_pages.png" added.
no Manual page in GUIs of r.modis.*
  Priority: normal | Milestone: 7.0.5
Comment (by neteler):
See also #2968 for a similar issue
Ticket URL: <http://trac.osgeo.org/grass/ticket/2865#comment:10&gt;
I tried removing all extensions, then removing {{{~./grass7/addons}}} as
in #2968 and {{{g.extension r.modis}}} still yields the same error as
Compiling...
   File "/tmp/grass7-veroandreo-17563/tmpvAd7vx/r.modis/scrip
ts/r.modis.download", line 94, in <module>
ts/r.modis.import", line 100, in <module>
get_proj
Installing...
/usr/bin/install: cannot stat ‘/tmp/grass7-veroandreo-1756
3/tmpvAd7vx/r.modis/docs/html/r.modis.download.html’: No
3/tmpvAd7vx/r.modis/docs/html/r.modis.import.html’: No
At {{{~.grass7/addons/docs/html/}}} there's only r.modis.html and not
r.modis.import.html nor r.modis.download.html, if that's of any help.
Ticket URL: <http://trac.osgeo.org/grass/ticket/2865#comment:11&gt;
Comment (by lucadelu):
Replying to [comment:11 veroandreo]:
They are missing also in the
[https://grass.osgeo.org/grass70/manuals/addons/ Addons documentation]
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:12&gt;
All the errors disappeared at some point (I'm now on r68704), and the
gui's for {{{r.modis.import}}} and {{{r.modis.download}}} have their
respective manual sections as expected.
Should this ticket be closed?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:13&gt;
There are still errors (tested with 7.0.5svn):
Fetching <r.modis> from GRASS-Addons SVN repository (be patient)...
Compiling...
   File "/tmp/tmp0yBF4p/r.modis/scripts/r.modis.download", line 94, in
<module>
   File "/tmp/tmp0yBF4p/r.modis/scripts/r.modis.import", line 100, in
<module>
Ticket URL: <http://trac.osgeo.org/grass/ticket/2865#comment:14&gt;
In [changeset:"69221" 69221]:
#!CommitTicketReference repository="" revision="69221"
r.modis: attempt to fix compilation, see #2865
Ticket URL: </ticket/2865#comment:15>
In [changeset:"69222" 69222]:
#!CommitTicketReference repository="" revision="69222"
r.modis: another attempt to fix compilation (order), see #2865
Ticket URL: </ticket/2865#comment:16>
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.modis
Changes (by martinl):
* status: new => closed
* resolution: => fixed
Comment:
Fixed by r69221 and r69222.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:17&gt;
      Type: defect | Status: reopened
Changes (by mlennert):
* status: closed => reopened
* resolution: fixed =>
Comment:
Reopening, because using a freshly checked out trunk (r69714) and having
erased the entire .grass7 directory, I still get the same error for
r.modis:
> g.extension r.modis
Compiling...
   File
"/tmp/grass7-mlennert-31361/tmpoyXxmW/r.modis/scripts/r.modis.download",
make[1]: *** [r.modis.download.tmp.html] Erreur 1
   File
"/tmp/grass7-mlennert-31361/tmpoyXxmW/r.modis/scripts/r.modis.import",
make[1]: *** [r.modis.import.tmp.html] Erreur 1
Installing...
/usr/bin/install: impossible d'évaluer
'/tmp/grass7-mlennert-31361/tmpoyXxmW/r.modis/docs/html/r.modis.download.html':
Aucun fichier ou dossier de ce type
make[1]: *** [install] Erreur 1
'/tmp/grass7-mlennert-31361/tmpoyXxmW/r.modis/docs/html/r.modis.import.html':
make: *** [installsubdirs] Erreur 2
ATTENTION: Installation failed, sorry. Please check above error messages.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:18&gt;
  Priority: normal | Milestone: 7.0.7
Changes (by veroandreo):
* status: reopened => closed
Comment:
I cannot reproduce the error anymore, closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2865#comment:20&gt;
