#2875: Python testsuite failing with UnicodeDecodeError
Reporter: marisn | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: Tests | Version: svn-trunk
Keywords: | CPU: Unspecified
Platform: Linux |
Unfortunately it is not possible to run tests as test suite is failing
itself (has anyone written tests for test suite?):
ERROR: test_seed_required (__main__.TestRandFunction)
Test that seed is required when rand() is used
File "raster/r.mapcalc/testsuite/test_r_mapcalc.py", line 99, in
test_seed_required
self.assertModuleFail('r.mapcalc', expression='rand_x = rand(1, 200)')
File "/home/maris/soft/grass_trunk/dist.x86_64-pc-linux-
gnu/etc/python/grass/gunittest/case.py", line 1180, in assertModuleFail
module.run()
gnu/etc/python/grass/pygrass/modules/interface/module.py", line 713, in
run
module=self.name, errors=stderr)
gnu/etc/python/grass/exceptions/__init__.py", line 71, in __init__
msg += _(". See the following errors:\n%s") % errors
UnicodeDecodeError: 'ascii' codec can't decode byte 0xc4 in position 29:
ordinal not in range(128)
The largest question is - should there be strings for translation at all?
I think not as most of low level errors and debug information is not
marked for translation. Tests should be run by developers not end users
thus I don't see a point in translating such strings.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2875>
