#2885: wxGUI Location Creation Wizard: UnicodeEncoreError when GISDBASE has
accents in path
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: location wizard encoding | CPU: Unspecified
Platform: Unspecified |
In trunk (but not int release70), testing with a grass database located in
/home/mlennert/DonnéesGRASS, I get the following error when trying to
create a new location with the location creation wizard. The error appears
when I click on the 'Finish' button, and the location is not created.
File "/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-linux-
gnu/gui/wxpython/gis_set.py", line 510, in OnWizard
grassdatabase = self.tgisdbase.GetValue())
gnu/gui/wxpython/location_wizard/wizard.py", line 1918, in __init__
msg = self.OnWizFinished()
gnu/gui/wxpython/location_wizard/wizard.py", line 2067, in OnWizFinished
current_gdb = grass.gisenv()['GISDBASE'].decode(sys.stdin.encoding)
File "/usr/lib/python2.7/encodings/utf_8.py", line 16, in decode
return codecs.utf_8_decode(input, errors, True)
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in
position 19: ordinal not in range(128)
accents in path
Resolution: | Keywords: location wizard encoding
Comment (by mlennert):
Replying to [comment:1 marisn]:
> This seems to be an side effect of r64044 while fixing #2205 Time for
another band-aid?
> See: https://trac.osgeo.org/grass/ticket/2205#comment:5
> How are you running GRASS - from a terminal or launching from a icon (no
terminal)?
> If from terminal, what is the output of locale?
accents in path
Comment (by marisn):
I think I see where is the problem. As usual - GRASS developers are not
following Unicode best practice (decode early, encode late) and ignoring
Pythonic approach in Python code (f* byte strings, use Unicode internally
everywhere. Yes, everywhere. No exceptions).
A correct approach would be to decode any incoming strings as soon as they
enter Python code i.e. in core.read_command (see patch), still that will
cause a huge breakage of whole wxgui till all str() occurrences (also
implicit ones!) will be transformed to unicode() ones (as in the example
patch for dbmgr).
Here is a hack around the issue (without breaking #2205) but I consider it
to be a wrong way to go:
Index: gui/wxpython/location_wizard/wizard.py
# current GISDbase or a new one?
- current_gdb =
+ current_gdb = grass.gisenv()['GISDBASE']
+ if isinstance(current_gdb, bytes):
+ ENCODING = locale.getdefaultlocale()[1]
+ if ENCODING is None:
+ ENCODING = 'UTF-8'
+ current_gdb = current_gdb.decode(ENCODING)
if current_gdb != database:
# change to new GISDbase or create new one
if os.path.isdir(database) != True:
I assume that it makes clear why this is a bad idea.
accents in path
Comment (by annakrat):
I suggest to bring this up on the mailing list, rather than this ticket
since it's a long standing issue and there are different opinions on this.
I would also like to see how should we deal with these problems in regard
to Python 3.
accents in path
Priority: normal | Milestone: 7.2.1
Comment (by wenzeslaus):
In [changeset:"70336" 70336]:
#!CommitTicketReference repository="" revision="70336"
wxGUI: use library function for decode of gisdbase string in location
wizard (see #2885 and r70335)
accents in path
Another possible traceback besides the one reported is:
File "/usr/lib/grass72/gui/wxpython/gis_set.py", line 531, in OnWizard
grassdatabase=self.tgisdbase.GetValue())
File "/usr/lib/grass72/gui/wxpython/location_wizard/wizard.py", line
2327, in __init__
2486, in OnWizFinished
TypeError: decode() argument 1 must be string, not None
However, I cannot reproduce this issue on my machine. Unicode in GRASS GIS
db path works. Can someone test it?
If I set everything from `locale` to nothing, I get different error, but
I'm not sure if that's even supposed to work (no encoding set but unicode
in paths).
accents in path
Replying to [comment:7 wenzeslaus]:
This solves the issue for me in trunk.
Can this be backported to 7.2 (where I still get the error) ?
