[GRASS-dev] [GRASS GIS] #2912: raster_what() not compliant with localised version of GRASS
Reporter: andbal | Owner: grass-dev@…
     Type: defect | Status: new
Priority: major | Milestone: 7.0.4
Component: Python | Version: svn-trunk
Keywords: grass.script python translation | CPU: x86-64
Platform: Linux |
Writing a python script, I found that the {{{grass.script.raster_what()}}}
output dictionary has different keys depending on language used in GRASS.
The following python code:
{{{#!python
point = grass.raster_what('clump', [[x,y]])[0]
print(type(point), point)
returns (with Italian GRASS):
{{{#!python
<type 'dict'> {'clump': {'color': '143:247:067', 'etichetta': '',
'valore': '1'}}
Changing language to English, returns:
{{{#!python
<type 'dict'> {'clump': {'color': '151:149:192', 'value': '1', 'label':
Changing language to German, returns:
{{{#!python
<type 'dict'> {'clump': {'Farbe': '099:113:108', 'value': '1', 'label':
The translation seems to depend on the GRASS localisations and make
impossible access to the dictionary keys in a general way.
Anyway a workaround could be achieved using
{{{grass.script.read_command('r.what')}}} and accessing to the list
values.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912&gt;
Resolution: | Keywords: grass.script python translation
       CPU: x86-64 | Platform: Linux
Comment (by mlennert):
Replying to [ticket:2912 andbal]:
{{{grass.script.raster_what()}}} output dictionary has different keys
This comes from line 191 in lib/python/script/raster.py where these labels
are noted as translatable strings. I agree that this is a very bad idea
and that such dictionary keys should not be translatable.
Unless anyone gives a good reason for the contrary, I will change the
vector of labels to non-translatable. This might break existing scripts,
but I think this is necessary.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:1&gt;
Comment (by marisn):
Replying to [comment:1 mlennert]:
labels are noted as translatable strings. I agree that this is a very bad
idea and that such dictionary keys should not be translatable.
Then also add line 184 ("No data").
This also needs to be explicitly stated in docstring that it is callers
responsibility to use localized version of key values before they are
displayed to the end user.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:2&gt;
Comment (by lucadelu):
In the attached diff I propose a change, because the actual behavior is
useful for GUI modules but not for other uses
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:3&gt;
Changes (by lucadelu):
* Attachment "raster_what.diff" added.
* Attachment "raster_what.diff" removed.
Comment (by annakrat):
Replying to [comment:3 lucadelu]:
I would prefer to avoid the `gui` parameter. Instead we could have a
wrapper function raster_what in wxpython/core/utils.py which would replace
the labels with the translatable ones? Sorry, no time for this right now,
maybe later.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:4&gt;
Replying to [comment:4 annakrat]:
maybe later.
Can you explain a little bit more why you don't like gui parameter? Your
proposal seems to me a duplication of code...
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:5&gt;
Replying to [comment:5 lucadelu]:
maybe later.
I didn't like the gui parameter, perhaps `localized=False` would make more
sense when you want to use localized names in a script, not just in the
gui.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:6&gt;
Replying to [comment:6 annakrat]:
more sense when you want to use localized names in a script, not just in
the gui.
Ok, if it is only parameter's name, it is not problem to change. I like
`localized`. Could I submit the code with `localized` parameter instead
`gui` one?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:7&gt;
Replying to [comment:7 lucadelu]:
the gui.
`gui` one?
Sure, if you tested it with different locale and it behaves as expected.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:8&gt;
Replying to [comment:8 annakrat]:
committed with test in r67874.
Tests are needed before backport.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:9&gt;
Comment (by andbal):
Replying to [comment:9 lucadelu]:
I tried the testsuite code with two languages other than english and gave
back 'OK' in both cases.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:10&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: grass.script python translation
Changes (by andbal):
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:11&gt;
      Type: defect | Status: reopened
Changes (by annakrat):
* status: closed => reopened
* resolution: fixed =>
Comment:
As far as I know, it hasn't been backported yet.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:12&gt;
  Priority: major | Milestone: 7.0.5
Comment (by martinl):
Can be backport done?
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:14&gt;
Replying to [comment:14 martinl]:
Yes, please do it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/2912#comment:15&gt;
* status: reopened => closed
Comment:
In [changeset:"69242" 69242]:
#!CommitTicketReference repository="" revision="69242"
python script: backported raster_what function to work with or without
localized labels fixed #2912
Ticket URL: </ticket/2912#comment:16>
