#2925: Fail early in r.modis.download when omitting folder
Reporter: pmav99 | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Addons | Version: unspecified
Keywords: r.modis.download | CPU: Unspecified
Platform: Unspecified |
According to `r.modis.download` documentation
> By default, the downloaded files are stored in the path where the
setting file is saved. The user can change this directory with folder
option. The user has to set the folder option if user and password are
sent by standard input.
If you specify the `username/password` from stdin and omit `folder` then
you get the following traceback
r.modis.download
settings=/home/grassuser/grassdata/modis/PERMANENT/.tmp/fa83d4fcd2cd/193.0
startday=2016-02-14 endday=2016-02-14
WARNING: Option 'tiles' not set. Downloading all available tiles
File "/home/grassuser/.grass7/addons/scripts/r.modis.download", line
248, in <module>
sys.exit(main())
227, in main
modisOgg.connect()
File "/home/grassuser/.grass7/addons/etc/r.modis/downmodis.py", line
311, in connect
if len(self.dirData) == 0:
AttributeError: downModis instance has no attribute 'dirData'
(Wed Feb 17 16:45:04 2016) Command finished (11 min 17 sec)
I think that it might make sense to add an early check instead of waiting
for such a long time before aborting.
Priority: normal | Milestone: 7.0.6
Resolution: | Keywords: r.modis.download
Comment (by lucadelu):
Replying to [ticket:2925 pmav99]:
> r.modis.download
248, in <module>
> sys.exit(main())
227, in main
> modisOgg.connect()
311, in connect
waiting for such a long time before aborting.
Sorry but I'm not able to reproduce the error.
Otherwise your example is using the settings so you are not using
username/password from standard input
