#2928: query tool does not work in wx display
Reporter: veroandreo | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.1.0
Component: wxGUI | Version: svn-trunk
Keywords: query tool | CPU: x86-64
Platform: Linux |
Query tool in grass71 (r67891) does not work with wx display (d.mon wx0),
neither for raster maps, nor for vector maps. In both cases I get the
following error:
File "/home/veroandreo/software/grass-7.1.svn/dist.x86_64-pc-linux-
gnu/gui/wxpython/mapwin/buffered.py", line 1236, in MouseActions
self.OnLeftUp(event)
gnu/gui/wxpython/mapwin/buffered.py", line 1413, in OnLeftUp
self.mapQueried.emit(x=self.mouse['end'][0], y=self.mouse['end'][1])
gnu/etc/python/grass/pydispatch/signal.py", line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
gnu/etc/python/grass/pydispatch/dispatcher.py", line 349, in send
**named
gnu/etc/python/grass/pydispatch/robustapply.py", line 60, in robustApply
return receiver(*arguments, **named)
gnu/gui/wxpython/mapdisp/frame.py", line 870, in Query
self.QueryMap(east, north, qdist, rast, vect)
gnu/gui/wxpython/mapdisp/frame.py", line 919, in QueryMap
self._highlighter_layer.Clear()
gnu/gui/wxpython/gui_core/vselect.py", line 377, in Clear
self.mapdisp.RemoveQueryLayer()
AttributeError: 'NoneType' object has no attribute 'RemoveQueryLayer'
In rel_branch (r67880) it does work both for raster and vector maps, but
in console I get the following every time I click somewhere in the wx
display
Resolution: | Keywords: query tool
CPU: x86-64 | Platform: Linux
Comment (by veroandreo):
Thanks, Anna! Works fine now both using d.mon and the main map display in
the GUI. However, in both cases, the first time I click over the displayed
map, I still get this message in the terminal:
Type: defect | Status: closed
Resolution: fixed | Keywords: query tool
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
Replying to [comment:3 veroandreo]:
in the GUI. However, in both cases, the first time I click over the
displayed map, I still get this message in the terminal:
> (main.py:9791): Gtk-CRITICAL **: gtk_widget_set_size_request: assertion
'height >= -1' failed
Thanks. The gtk error is unrelated and I think harmless.
