#2981: r.watershed & blocking
Reporter: mankoff | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.4
Component: Raster | Version: 7.0.1
Keywords: | CPU: OSX/Intel
Platform: MacOSX |
I'm not sure if this is a bug, but I think so. When I set the
{{{blocking}} option to {{{r.watershed}}}, I see no difference in the
accumulation map.
The example below, which should work on the NC data set, creates a
"blockage" at 30 m, runs {{{r.watershed}}} with and without the blockage,
and compares results.
Replying to [ticket:2981 mankoff]:
accumulation map.
The `blocking` option only affects RUSLE-related outputs `length_slope`
and `slope_steepness`. Slope lengths are calculated from drainage paths
through the terrain. Path tracing stops as soon as a blocking cell or a
stream cell is encountered.
