[GRASS-dev] [GRASS GIS] #3037: r.import - output name should not be required with -e flag
Reporter: guano | Owner: grass-dev@…
Priority: normal | Milestone: 7.0.5
Component: wxGUI | Version: 7.0.3
Keywords: import | CPU: Unspecified
Platform: All |
In r.import (import with reprojection), the -e flag should ignore if there
is an output name defined, much like the 'remove mask' option.
Also, the output name could be set to be the same as the input by default,
like in r.in.gdal.
Ticket URL: <http://trac.osgeo.org/grass/ticket/3037&gt;
Resolution: | Keywords: import
       CPU: Unspecified | Platform: All
Comment (by annakrat):
Try r68466.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:1&gt;
Comment (by martinl):
Backport candidate?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:2&gt;
Replying to [comment:2 martinl]:
> Backport candidate?
Yes, but someone please confirm it works first.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:3&gt;
Tested, seems to work.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:4&gt;
  Priority: normal | Milestone: 7.3.0
There is probably still a bug, when I run
r.import
in=/opt/geodata/piemont/landsat_4_5_7_8/LE71940292015195NSG00_sr_band5_piemont.tif
-e
in the location which match the input data, the resolution is not printed
and moreover output map (rimport_tmp) is not deleted.
r.import
-e
Proceeding with import of 1 raster bands...
Importing raster map <rimport_tmp>...
0..3..100
g.list raster pat=rimport_tmp
rimport_tmp
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:6&gt;
Changes (by martinl):
* milestone: 7.3.0 => 7.0.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:7&gt;
The question is what should the r.import do when no reprojection is needed
and user uses -e flag. Should the raster be imported, then we print its
resolution and delete it? That's probably consistent, but seems weird.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:8&gt;
  Priority: normal | Milestone: 7.0.7
Still relevant?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:11&gt;
  Priority: normal | Milestone: 7.6.2
* milestone: 7.0.7 => 7.6.2
Ticket URL: <https://trac.osgeo.org/grass/ticket/3037#comment:12&gt;
