[GRASS-dev] [GRASS GIS] #3047: MySQL driver failed to install
Reporter: fpouw | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Database | Version: 7.0.4
Keywords: mysql driver | CPU: Unspecified
Platform: MSWindows 7 |
A recent install of GRASS7 is missing the MySQL driver.
The result of db.driver does not list 'mysql' it and the db.connect
command (executed without a driver specified) returns an error that
'mysql' is out of the domain of accepted values.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047&gt;
Resolution: | Keywords: mysql driver, wingrass
       CPU: Unspecified | Platform: MSWindows 7
Changes (by martinl):
* keywords: mysql driver => mysql driver, wingrass
Comment:
Right, WinGRASS is currently built without mysql support, see build log
(1)
(1)
http://wingrass.fsv.cvut.cz/grass70/x86_64/logs/log-r68516-175/package.log
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:1&gt;
Comment (by neteler):
Replying to [comment:1 martinl]:
(1)
> (1)
The log says
"checking whether to use MySQL... no"
Is it a matter of enabling it in the configuration or more complex issues?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:2&gt;
Comment (by martinl):
Replying to [comment:2 neteler]:
issues?
I am planning to take a look on this issue. But first of all I need to fix
issued related to the building server (grass72).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:3&gt;
In [changeset:"68620" 68620]:
#!CommitTicketReference repository="" revision="68620"
wingrass: add mysql_config (see #3047)
Ticket URL: </ticket/3047#comment:4>
In [changeset:"68621" 68621]:
#!CommitTicketReference repository="" revision="68621"
wingrass: enable mysql support (see #3047)
Ticket URL: </ticket/3047#comment:5>
In [changeset:"68653" 68653]:
#!CommitTicketReference repository="" revision="68653"
wingrass: disable mysql support (broken build), see #3047 for details
Ticket URL: </ticket/3047#comment:6>
The MYSQL support has been disabled due to compilation errors
C:/OSGeo4W64/include/mysql.h:64:19: error: unknown type name 'SOCKET'
  #define my_socket SOCKET
I hope will be fixed later.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:7&gt;
Replying to [comment:7 martinl]:
For a potential solution, see
http://www.technowise.in/2009/08/fixing-socket-does-not-name-type-
error.html
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:8&gt;
Replying to [comment:8 neteler]:
error.html
Did anyone try the solution? Citation:
To fix this error, just include winsock.h before including mysql.h header
as shown below:
#include <winsock.h>
#include <mysql.h>
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:9&gt;
  Priority: normal | Milestone: 7.8.0
* milestone: 7.0.7 => 7.8.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3047#comment:12&gt;
