[GRASS-dev] [GRASS GIS] #3050: Set size in d.northarrow
Reporter: wenzeslaus | Owner: grass-dev@…
Priority: minor | Milestone: 7.3.0
Component: Display | Version: svn-trunk
Keywords: d.northarrow, cartography, gsoc2016 | CPU: Unspecified
Platform: Unspecified |
Size of the north arrow cannot be changed. All symbols are scaled to one
common size, that's good, but this size should be further rescaled by a
value of a `size` option.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3050&gt;
      Type: | Status: new
  enhancement |
Resolution: | Keywords: d.northarrow, cartography, gsoc2016
       CPU: | Platform: Unspecified
  Unspecified |
Comment (by lazaa):
Replying to [ticket:3050 wenzeslaus]:
The size of symbol is manually tuned and for each symbol is quite
different. I would add {{{size}}} option. If user doesn't use {{{size}}}
manually tuned size will be used. But if user writes {{{size=25}}} for
some symbols it will have increasing size effect and for others decreasing
size effect. Is it OK? User would have to find right size for a symbol and
after that if he changed mind and wanted use another symbol he would have
to find the right size one more time.
     /* sizes manually tuned */
     switch (n_arrow_num[0]) {
     case '7':
         symbol_size = 23.;
         break;
     case '8':
     case '9':
         symbol_size = 17.;
         break;
     case 'b':
         symbol_size = 80.;
         break;
     case 'f':
         symbol_size = 100.;
         break;
Ticket URL: <https://trac.osgeo.org/grass/ticket/3050#comment:1&gt;
      Type: | Status: new
  enhancement |
  Unspecified |
Comment (by wenzeslaus):
Replying to [comment:1 lazaa]:
> >All symbols are scaled to one common size, that's good, but this size
should be further rescaled by a value of a `size` option.
> If user doesn't use {{{size}}} manually tuned size will be used. But if
user writes {{{size=25}}} for some symbols it will have increasing size
effect and for others decreasing size effect.
I don't know what is better if to scale, as I suggested, which is
different behavior from all the other modules (so it might be better to
call it `scale`), or if it is better to overwrite the size, as you suggest
and consequently make it potentially harder for the user (symbols in
d.vect behave the same but they have more similar sizes).
For now, I suggest to skip this issue.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3050#comment:2&gt;
      Type: | Status: new
  enhancement |
  Priority: minor | Milestone: 7.4.1
  Unspecified |
Comment (by martinl):
Can we close the issue?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3050#comment:5&gt;
      Type: | Status: new
  enhancement |
  Unspecified |
Comment (by annakrat):
No, it's still valid problem. But I am not sure which is the right
solution at this point.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3050#comment:6&gt;
