[GRASS-dev] [GRASS GIS] #3089: exec_command fails if '.exe' not included in filename.
Reporter: artegion | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.5
Component: Default | Version: svn-releasebranch72
Keywords: | CPU: Unspecified
Platform: MSWindows 7 |
Example (from v.centroids.py):
gscript.exec_command("v.category", type='area', **options)
fails with
   File "C:\grass72\GRASS GIS 7.2.svn/scripts/v.centroids.py", line 68, in
<module>
     main()
   File "C:\grass72\GRASS GIS 7.2.svn/scripts/v.centroids.py", line 62, in
main
   File "C:\grass72\GRASS GIS 7.2.svn\etc\python\grass\script\core.py",
line 553,
  in exec_command
     os.execvpe(prog, args, env)
   File "C:\grass72\GRASS GIS 7.2.svn\Python27\lib\os.py", line 353, in
execvpe
     _execvpe(file, args, env)
   File "C:\grass72\GRASS GIS 7.2.svn\Python27\lib\os.py", line 380, in
_execvpe
     func(fullname, *argrest)
OSError: [Errno 2] No such file or directory
while modified source
gscript.exec_command("v.category.exe", type='area', **options)
works correctly.
It seems like os.execvpe does not use PATHEXT environment variable (maybe
because dot in filename overrides PATHEXT and ".category" is taken as file
extension)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: MSWindows 7
Comment (by glynn):
Replying to [ticket:3089 artegion]:
(maybe because dot in filename overrides PATHEXT and ".category" is taken
as file extension)
In this specific case, I'd suggest just using run_command() instead of
exec_command(). On Windows, they amount to essentially the same thing
anyhow; Windows doesn't have a "real" execve(); it just executes the
command as a child process, waits for the child to terminate, then
exit()s.
There aren't many plausible situations where exec_command() is actually
needed; it mostly just provides a very slight efficiency gain (on Unix) by
not needing to keep the parent process alive for the duration of the
child.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089#comment:1&gt;
Comment (by martinl):
Replying to [comment:1 glynn]:
exit()s.
done in all active branches (r68954, r68955, r68956). Testing welcome,
will be included in the next daily build (1) - so 14/7+.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089#comment:2&gt;
      Type: defect | Status: closed
Component: Vector | Version: svn-releasebranch72
Resolution: fixed | Keywords: v.centroids
Changes (by martinl):
* keywords: => v.centroids
* status: new => closed
* component: Default => Vector
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089#comment:3&gt;
Comment (by neteler):
Was this the only instance of this call?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089#comment:4&gt;
Replying to [comment:4 neteler]:
yes, seems to be.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3089#comment:5&gt;
