[GRASS-dev] [GRASS GIS] #3103: vector import wizzard and v.in.ogr --ui fails to import a vector
Reporter: hellik | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.3.0
Component: Vector | Version: svn-trunk
Keywords: | CPU: x86-64
Platform: MSWindows 8 |
trying to import a vector (shape file) with the import common vector
format wizzards I get:
   File "C:\OSGEO4~1\apps\Python27\lib\site-packages\wx-2.8
-msw-unicode\wx\lib\filebrowsebutton.py", line 140, in
OnChanged
self.changeCallback(evt)
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\gu
i_core\gselect.py", line 2055, in OnUpdate
self._reloadLayers()
i_core\gselect.py", line 2155, in _reloadLayers
self.reloadDataRequired.emit(listData=listData, data=data)
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\etc\python\gras
s\pydispatch\signal.py", line 229, in emit
dispatcher.send(signal=self, *args, **kwargs)
s\pydispatch\dispatcher.py", line 349, in send
**named
s\pydispatch\robustapply.py", line 60, in robustApply
return receiver(*arguments, **named)
   File "C:\OSGEO4~1\apps\grass\grass-7.3.svn\gui\wxpython\mo
dules\import_export.py", line 541, in reload
self.list.LoadData(listData)
i_core\widgets.py", line 1024, in LoadData
index = self.InsertStringItem(sys.maxsize, str(item[0]))
-msw-unicode\wx\lib\mixins\listctrl.py", line 753, in
__InsertStringItem_
index = self.InsertImageStringItem(index, label, 0)
-msw-unicode\wx\_controls.py", line 4769, in
return _controls_.ListCtrl_InsertImageStringItem(*args,
**kwargs)
OverflowError
Python int too large to convert to C long
then v.in.ogr --ui, selecting the shapefile by browsing to the file, no
layer is detected.
tested
System Info
GRASS Version: 7.3.svn
GRASS SVN revision: r68983
Build date: 2016-07-16
Build platform: x86_64-w64-mingw32
GDAL: 2.1.0
PROJ.4: 4.9.2
GEOS: 3.5.0
SQLite: 3.7.17
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3103&gt;
  Priority: critical | Milestone: 7.3.0
Resolution: | Keywords:
       CPU: x86-64 | Platform: MSWindows 8
Changes (by hellik):
* priority: normal => critical
Ticket URL: <https://trac.osgeo.org/grass/ticket/3103#comment:1&gt;
Comment (by hellik):
Replying to [ticket:3103 hellik]:
just tested with the NC sample data set,
first
v.out.ogr input=firestations@PERMANENT output=D:\temp\test\myfirest.shp
format=ESRI_Shapefile
then trying to reimport it, no chance.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3103#comment:2&gt;
Replying to [comment:2 hellik]:
> first
at least it works by the command line:
v.in.ogr input=D:\temp\test\myfirest.shp output=myfstations
Check if OGR layer <myfirest> contains polygons...
Column name <cat> renamed to <cat_>
Importing 71 features (OGR layer <myfirest>)...
Erstelle Topologie für die Vektorkarte <myfstations@user1>...
Registriere Primitive...
71 primitives registered
71 Vertices registriert
Erzeuge Flächen...
0 areas built
0 isles built
Füge Inseln hinzu...
Füge Zentroide hinzu...
Anzahl der Knoten: 0
Anzahl der Primitive: 71
Anzahl der Punkte: 71
Anzahl der Linien: 0
Anzahl der Grenzen: 0
Anzahl der Zentroide: 0
Anzahl der Flächen: 0
Anzahl der Inseln: 0
(Sun Jul 17 11:51:03 2016) Befehl ausgeführt (0 Sek)
but not by GUI
Ticket URL: <https://trac.osgeo.org/grass/ticket/3103#comment:3&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by annakrat):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"68999" 68999]:
#!CommitTicketReference repository="" revision="68999"
wxGUI: fix #3103 - sys.maxsize doesn't work in 64bit windows
Ticket URL: </ticket/3103#comment:4>
