[GRASS-dev] [GRASS GIS] #3150: Simple r.out.png region enhancement
Reporter: huhabla | Owner: grass-dev@…
Priority: trivial | Milestone:
Component: Default | Version: svn-trunk
Keywords: r.out.png | CPU: Unspecified
Platform: Unspecified |
I would like to post a patch that enables direct region settings in
r.out.png. This patch is only useful if the current region should not be
changed or can not be changed due to access restrictions of the mapset.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3150&gt;
Resolution: | Keywords: r.out.png
Changes (by huhabla):
* Attachment "r.out.png.patch" added.
r.out.png region patch
  Priority: trivial | Milestone: 7.0.5
Component: Raster | Version: svn-trunk
Changes (by martinl):
* component: Default => Raster
* milestone: => 7.0.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/3150#comment:1&gt;
  Priority: trivial | Milestone: 7.2.0
* milestone: 7.0.5 => 7.2.0
Comment:
Changing milestone at least to 7.2.0 (only bugfixes can go to relbr70).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3150#comment:2&gt;
  Priority: trivial | Milestone: 7.4.2
Resolution: | Keywords: r.out.png region
Changes (by wenzeslaus):
* keywords: r.out.png => r.out.png region
Comment:
Replying to [ticket:3150 huhabla]:
r.out.png.
I agree that this would come handy time to time. For example, G7:r.mapcalc
(>=7.4) has region option to customize the region based on the inputs.
General modifications of region, such as the one you suggest, would apply
to many modules.
I think this would be better addressed generally as we discussed in
[https://lists.osgeo.org/pipermail/grass-dev/2016-September/082412.html
Adding an expert mode to the parser] and
[https://lists.osgeo.org/pipermail/grass-dev/2016-November/082927.html
Passing computational region to individual commands].
I suggest to close this as won't fix and open another ticket suggesting
change on the library and parser level or on the level of grass.py
covering the --exec case.
> This patch is only useful if the current region should not be changed or
I was also in this situation and really for outputs and rendering, even
many GUI operations, there is no need to have any write access or
ownership (see also #2511). The current solution for this particular use
case and r.out.png is the GRASS_REGION environmental variable.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3150#comment:8&gt;
