[GRASS-dev] [GRASS GIS] #3193: r.out.gdal: add AUTHORITY node to the srs info of the exported raster
Reporter: hellik | Owner: grass-dev@…
Priority: major | Milestone: 7.2.0
Component: Raster | Version: svn-trunk
Keywords: | CPU: All
Platform: All |
test case in a location created by an EPSG code
g.proj -p
-PROJ_INFO-------------------------------------------------
name : MGI / Austria GK Central
datum : hermannskogel
ellps : bessel
proj : tmerc
lat_0 : 0
lon_0 : 13.33333333333333
k : 1
x_0 : 0
y_0 : -5000000
no_defs : defined
towgs84 : 577.326,90.129,463.919,5.1366,1.4742,5.2970,2.4232
-PROJ_EPSG-------------------------------------------------
epsg : 31255
-PROJ_UNITS------------------------------------------------
unit : meter
units : meters
meters : 1
export a raster by r.out.gdal and do gdalinfo
gdalinfo raster_export_by_grass.tif
Driver: GTiff/GeoTIFF
Files: raster_export_by_grass.tif
Size is 7201, 7001
Coordinate System is:
PROJCS["MGI / Austria GK Central",
     GEOGCS["bessel",
         DATUM["Militar_Geographische_Institute",
             SPHEROID["Bessel_1841",6377397.155,299.1528128],
             TOWGS84[577.326,90.129,463.919,5.1366,1.4742,5.297,2.4232]],
         PRIMEM["Greenwich",0],
         UNIT["degree",0.0174532925199433]],
     PROJECTION["Transverse_Mercator"],
     PARAMETER["latitude_of_origin",0],
     PARAMETER["central_meridian",13.33333333333333],
     PARAMETER["scale_factor",1],
     PARAMETER["false_easting",0],
     PARAMETER["false_northing",-5000000],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]]]
Origin = (-96005.000000000000000,230005.000000000000000)
Pixel Size = (10.000000000000000,-10.000000000000000)
Metadata:
   AREA_OR_POINT=Area
   TIFFTAG_SOFTWARE=GRASS GIS 7.3.svn with GDAL 2.1.1
Image Structure Metadata:
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -96005.000, 230005.000) ( 12d 3'57.90"E, 47d12' 8.96"N)
Lower Left ( -96005.000, 159995.000) ( 12d 4'50.98"E, 46d34'22.11"N)
Upper Right ( -23995.000, 230005.000) ( 13d 0'59.64"E, 47d12'32.62"N)
Lower Right ( -23995.000, 159995.000) ( 13d 1'12.91"E, 46d34'45.25"N)
Center ( -60000.000, 195000.000) ( 12d32'45.35"E, 46d53'30.77"N)
do gdal_translate and assign the srs
gdal_translate -a_srs EPSG:31255 raster_export_by_grass.tif
geotif_by_gdaltranslate.tif
check by gdalinfo
gdalinfo geotif_by_gdaltranslate.tif
Files: geotif_by_gdaltranslate.tif
        geotif_by_gdaltranslate.tif.aux.xml
Size is 7201, 7001
     GEOGCS["MGI",
             SPHEROID["Bessel 1841",6377397.155,299.1528128,
                 AUTHORITY["EPSG","7004"]],
             TOWGS84[577.326,90.129,463.919,5.137,1.474,5.297,2.4232],
             AUTHORITY["EPSG","6312"]],
         PRIMEM["Greenwich",0,
             AUTHORITY["EPSG","8901"]],
         UNIT["degree",0.0174532925199433,
             AUTHORITY["EPSG","9122"]],
         AUTHORITY["EPSG","4312"]],
     UNIT["metre",1,
         AUTHORITY["EPSG","9001"]],
     AUTHORITY["EPSG","31255"]] <<==
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=BAND
Corner Coordinates:
GDAL adds the ''AUTHORITY node'' of the corresponding EPSG code.
this may be help #3191 (and maybe also other GIS software reading GRASS
exported data).
also mentioned in a [https://lists.osgeo.org/pipermail/gdal-
dev/2016-October/045359.html GDAL ML thread]:
From what I can see the driver doesn't handle adding a new entry in the
spatial_ref_sys table if there's no AUTHORITY node, such as in your use
case.
Make sure a EPSG code is attached to
the input dataset, or assign it explictly
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193&gt;
Resolution: | Keywords: r.out.gdal,r.external.out
       CPU: All | Platform: All
Changes (by sbl):
* keywords: => r.out.gdal,r.external.out
Comment:
See also: #3059
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:1&gt;
  Priority: major | Milestone: 7.4.0
Comment (by martinl):
This functionality was recently implemented in trunk, right? Reference is
missing here.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:5&gt;
Comment (by mmetz):
Replying to [comment:5 martinl]:
is missing here.
It was implemented by martinl with r71303
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:6&gt;
Comment (by sbl):
Hmm... This is still an issue for me both in GRASS 7.4 (r72108) and GRASS
7.5 (r72157):\\
See also (sort of duplicate): #3048
g.proj -p
name : ETRS89 / UTM zone 33N
datum : etrs89
ellps : grs80
proj : utm
zone : 33
no_defs : defined
epsg : 25833
unit : meter
units : meters
meters : 1
r.external.out --verbose directory=/tmp extension=.tif format=GTiff
options=COMPRESS=LZW
r.mapcalc expression="test=1"
gdalinfo /tmp/test.tif
r.external.out -r
g.remove type=raster name=test -f
rm /tmp/test.tif
r.out.gdal -c input=test output=/tmp/test.tif createopt="COMPRESS=LZW" --o
In both cases gdalinfo shows:
PROJCS["UTM Zone 33, Northern Hemisphere",
     GEOGCS["grs80",
         DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["Geodetic_Reference_System_1980",6378137,298.257222101,
                 AUTHORITY["EPSG","7019"]],
             AUTHORITY["EPSG","6258"]],
     PARAMETER["central_meridian",15],
     PARAMETER["scale_factor",0.9996],
     PARAMETER["false_easting",500000],
     PARAMETER["false_northing",0],
     UNIT["metre",1,
Origin = (256495.000000000000000,6653695.000000000000000)
That means:
     AXIS["Easting",EAST],
     AXIS["Northing",NORTH],
     AUTHORITY["EPSG","25833"]]
is still missing at the bottom of the CRS information, compared to CRS
info with:
gdal_edit.py -a_srs EPSG:25833 /tmp/test.tif
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:7&gt;
Comment (by sbl):
This affects interoperability with e.g. GeoServer/GeoNode or QGIS
(https://issues.qgis.org/issues/14856).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:8&gt;
Comment (by hellik):
Replying to [comment:6 mmetz]:
is missing here.
tested with the example above:
g.proj -p
ellps : bessel
proj : tmerc
lat_0 : 0
k : 1
x_0 : 0
y_0 : -5000000
no_defs : defined
epsg : 31255
unit : meter
units : meters
meters : 1
r.out.gdal input=test1@test output=J:\test\test_write_auth.tif
format=GTiff createopt=COMPRESS=LZW,PREDICTOR=2,TILED=YES
gdalinfo test_write_auth.tif
Files: test_write_auth.tif
Size is 7201, 7001
     GEOGCS["bessel",
     UNIT["metre",1,
Metadata:
   AREA_OR_POINT=Area
   TIFFTAG_SOFTWARE=GRASS GIS 7.5.svn with GDAL 2.2.3
   COMPRESSION=LZW
   INTERLEAVE=BAND
Corner Coordinates:
gdal_translate -a_srs EPSG:31255 test_write_auth.tif
test_write_auth_assign_by_gdal.tif
Files: test_write_auth_assign_by_gdal.tif
Size is 7201, 7001
     GEOGCS["MGI",
     UNIT["metre",1,
     AUTHORITY["EPSG","31255"]] <==
Metadata:
   AREA_OR_POINT=Area
   INTERLEAVE=BAND
Corner Coordinates:
System Info
GRASS version: 7.5.svn
GRASS SVN revision: r72120
Build date: 2018-01-24
Build platform: i386-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.4
wxPython: 2.8.12.1
Platform: Windows-Vista-6.0.6002-SP2 (OSGeo4W)
comparing the gdalinfo of GRASS exported and GDAL assigned tif,
seems to be still missing
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:9&gt;
Comment (by mmetz):
Replying to [comment:9 hellik]:
Reference is missing here.
The functions were implemented in r71303. An EPSG code was only exported
with v.out.ogr. As of trunk r72160, an existing EPSG code is exported with
r.external.out, r.out.gdal, v.external.out, v.out.ogr.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:10&gt;
  Priority: major | Milestone: 7.4.1
Replying to [comment:10 mmetz]:
Backport candidat for 7.4.1?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:12&gt;
Comment (by mmetz):
Replying to [comment:12 hellik]:
exported with v.out.ogr. As of trunk r72160, an existing EPSG code is
exported with r.external.out, r.out.gdal, v.external.out, v.out.ogr.
It's a new feature, and EPSG codes should not be required in order to
support custom coordinate reference systems.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:13&gt;
tested with
System Info
GRASS SVN revision: r72194
Build date: 2018-01-30
Build platform: x86_64-w64-mingw32
GDAL: 2.2.3
PROJ.4: 4.9.3
GEOS: 3.5.0
SQLite: 3.17.0
Python: 2.7.5
wxPython: 2.8.12.1
Platform: Windows-8-6.2.9200 (OSGeo4W)
g.proj -p
ellps : bessel
proj : tmerc
lat_0 : 0
k : 1
x_0 : 0
y_0 : -5000000
no_defs : defined
epsg : 31255
unit : meter
units : meters
meters : 1
gdalinfo test_raster_authority.tif
Files: test_raster_authority.tif
Size is 170, 141
     GEOGCS["MGI",
             TOWGS84[577.326,90.129,463.919,5.1366,1.4742,5.297,2.4232],
     UNIT["metre",1,
Origin = (-161500.000000000000000,273250.000000000000000)
Pixel Size = (250.000000000000000,-250.000000000000000)
Metadata:
   AREA_OR_POINT=Area
   COMPRESSION=LZW
   INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( -161500.000, 273250.000) ( 11d11'10.74"E, 47d34'42.28"N)
Lower Left ( -161500.000, 238000.000) ( 11d11'56.99"E, 47d15'41.55"N)
Upper Right ( -119000.000, 273250.000) ( 11d45' 3.81"E, 47d35'15.35"N)
Lower Right ( -119000.000, 238000.000) ( 11d45'37.92"E, 47d16'14.25"N)
Center ( -140250.000, 255625.000) ( 11d28'27.33"E, 47d25'29.61"N)
  AUTHORITY["EPSG","XXXX"] is now exported in rasters too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:14&gt;
      Type: | Status: closed
  enhancement |
  Priority: major | Milestone: 7.6.0
Component: Raster | Version: svn-releasebranch76
Resolution: fixed | Keywords: r.external.out, r.out.gdal,
                         | v.external.out, v.out.ogr
Changes (by neteler):
* keywords: r.out.gdal,r.external.out => r.external.out, r.out.gdal,
* status: new => closed
* version: svn-trunk => svn-releasebranch76
* resolution: => fixed
* milestone: 7.4.2 => 7.6.0
Comment:
To be released in the upcoming 7.6.0; closing.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3193#comment:16&gt;
