[GRASS-dev] [GRASS GIS] #3216: Dropdown menu query_column in v.to.db shows columns of wrong table
Reporter: pvanbosgeo | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Default | Version: unspecified
Keywords: | CPU: Unspecified
Platform: Unspecified |
Concerns: The query_column option in the Query tab of the v.to.db function
Issue: when selecting layer 2 in the query_layer option, the dropdown menu
of the query_column still shows the column name of the attribute table
linked to layer 1 instead of the table linked to layer 2.
Warning: if one selects a column (e.g., VAR1) from the drop-down menu and
runs v.to.db, a error is raised that "ERROR: Cannot open cursor: 'SELECT
VAR1 FROM MYTAB WHERE cat = 15'"
Note: One can still type in the name of the required column, and the
function will run without problem.
I am running GRASS 7.3 on Ubuntu 16.04
Ticket URL: <https://trac.osgeo.org/grass/ticket/3216&gt;
Resolution: | Keywords:
Changes (by pvanbosgeo):
* Attachment "example.png" added.
Even though layer 2 is selected, the dropdown menu shows the column names
of the table linked to layer 1
Comment (by mlennert):
Replying to [ticket:3216 pvanbosgeo]:
function
menu of the query_column still shows the column name of the attribute
table linked to layer 1 instead of the table linked to layer 2.
AFAIK, this is an issue in every single module where a list of columns
comes from another source than the main 'map'. AFAIU, this is inherent to
the way this widget is programmed in the GUI. ISTR that there have been
discussions about this, but don't have the time to search for this. I
would guess that the widget would need some parameter with the name and
layer of the map from which to get the list of column...
Ticket URL: <https://trac.osgeo.org/grass/ticket/3216#comment:1&gt;
  Priority: normal | Milestone: 7.6.2
Changes (by martinl):
* milestone: 7.0.7 => 7.6.2
Comment:
Unable to reproduce bug in GRASS 7.6.0
Ticket URL: <https://trac.osgeo.org/grass/ticket/3216#comment:3&gt;
