#3247: i.superpixels.slic fails when region larger than 500x500 pix (on Win7)
Reporter: tgrippa | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.0.6
Component: Imagery | Version: unspecified
Resolution: | Keywords: i.superpixels.slic
CPU: Unspecified | Platform: MSWindows 7
Comment (by mlennert):
I can confirm segfault on Linux, but with different number of pixels:
g.region raster=ortho_2001_t792_1m n=220477 s=219456 e=638054 w=637033
res=1 -p
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: a=6378137 es=0.006694380022900787
north: 220477
south: 219456
west: 637033
east: 638054
nsres: 1
ewres: 1
rows: 1021
cols: 1021
cells: 1042441
i.superpixels.slic --overwrite group=ortho k=500 output=slic_segment
works, but
g.region raster=ortho_2001_t792_1m n=220479 s=219456 e=638056 w=637033
res=1 -p
zone: 0
datum: nad83
north: 220479
south: 219456
west: 637033
east: 638056
nsres: 1
ewres: 1
rows: 1023
cols: 1023
cells: 1046529
gives me a segfault. 1022x1022 sometimes does, sometimes doesn't.
Here's the backtrace I get in gdb, but I guess the addon needs to be
recompiled with debugging enabled:
#0 0x00007ffff70f9d3e in _IO_vfprintf_internal (s=0x7fffff7ff180,
format=0x7ffff7790b7b "%4d%%\b\b\b\b\b", ap=0x7fffff801828)
at vfprintf.c:1267
#1 0x00007ffff70fcc23 in buffered_vfprintf (s=0x7ffff744c520
<_IO_2_1_stderr_>, format=<optimized out>, args=<optimized out>)
at vfprintf.c:2325
#2 0x00007ffff70f9f15 in _IO_vfprintf_internal (s=0x7ffff744c520
<_IO_2_1_stderr_>, format=0x7ffff7790b7b "%4d%%\b\b\b\b\b",
ap=ap@entry=0x7fffff801828) at vfprintf.c:1293
#3 0x00007ffff7102157 in __fprintf (stream=<optimized out>,
format=format@entry=0x7ffff7790b7b "%4d%%\b\b\b\b\b")
at fprintf.c:32
#4 0x00007ffff7780e4a in G_percent (n=0, d=10, s=<optimized out>) at
percent.c:83
#5 0x0000555555555c21 in main (argc=<optimized out>, argv=<optimized
out>) at main.c:338
Here's the output with g.gisenv set=DEBUG=3:
D1/3: G_find_raster2(): name=ortho_2001_t792_1m mapset=PERMANENT
D2/3: G_file_name(): path =
/data/GRASS/DATA7/nc_spm_08/PERMANENT/cell/ortho_2001_t792_1m
/data/GRASS/DATA7/nc_spm_08/PERMANENT/fcell/ortho_2001_t792_1m
/data/GRASS/DATA7/nc_spm_08/PERMANENT/g3dcell/ortho_2001_t792_1m
/data/GRASS/DATA7/nc_spm_08/PERMANENT/cell_misc/ortho_2001_t792_1m/gdal
D3/3: create window mapping (1023 columns)
/data/GRASS/DATA7/nc_spm_08/PERMANENT/cell_misc/ortho_2001_t792_1m/null
D1/3: G_find_raster(): name=MASK mapset=user1
D2/3: G_file_name(): path = /data/GRASS/DATA7/nc_spm_08/user1/cell/MASK
Erreur de segmentation
Ticket URL: <https://trac.osgeo.org/grass/ticket/3247#comment:1>
