#3296: r.mapcalc: nmedian() unexpected results
Reporter: sbl | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.1
Component: Default | Version: svn-releasebranch72
Keywords: r.mapcalc,nmedian() | CPU: Unspecified
Platform: Unspecified |
Seems that the nmedian() function in r.mapcalc for both GRASS 7.0, GRASS
7.2 and trunk gives unexpected results.
The neighborhood modifer I used do not seem to cause the issue...
This:
g.region -p n=3 s=0 e=3 w=0 res=1
r.mapcalc expression="test=row()*col()" --o
r.mapcalc expression="nbh_test_r=(test[0,-1] - test)^2.0" --o
r.mapcalc expression="nbh_test_l=(test[0,1] - test)^2.0" --o
r.mapcalc expression="nmed_test=nmedian(((test[0,-1] -
test)^2.0,(test[0,1] - test)^2.0))" --o
should result in a horizontally striped map with values covering 1 (top
row), 4 (middle row, and 9 (bottom row). However, the leftmost column
contains values 0.2, 2.5, 6.5 (from top to bottom).
Yet, here - where values only differ from column to column -
r.mapcalc expression="test=col()" --o
only the top-left cell has an odd value of 0.5 while the rest has value 1
as expected...
In [changeset:"70674" 70674]:
#!CommitTicketReference repository="" revision="70674"
Do not calculate median if only one variable is provided.
Fixes #3296
In [changeset:"70675" 70675]:
#!CommitTicketReference repository="" revision="70675"
Fixes #3296 (backport of r70674)
In [changeset:"70676" 70676]:
#!CommitTicketReference repository="" revision="70676"
Replying to [comment:2 marisn]:
> Fixes #3296
Fixed in trunk r70683. You need to use the actual number of non-NULL
values to set the pointers a1, a2.
Replying to [comment:6 mmetz]:
> > Fixes #3296
Replying to [comment:7 neteler]:
> > > Fixes #3296
> Does(n't) this need to be backported?
