-<P>
-The driver is still in development. Currently the way to enable Cairo driver
-support is to build grass with
-<div class="code"><PRE>
-make USE_CAIRO=1
-</PRE></div>
+<P>The driver is still in development. Enable it by specifying
+<CODE>--with-cairo</CODE> when configuring GRASS. This
+requires a reasonably recent version of the Cairo libraries
+and a working pkg-config.</P>
-This requires a reasonably recent version of the cairo libraries (cairo.h).
<P>Antialiasing is enabled by default for bitmap formats. There is
currently no way of disabling this.</P>
> we should finish adding Cairo support by building it into the ./configure
> script.
> the attached patch also adds an extra test needed for ffmpeg.
> I do not know much about autoconf and ./configure scripts so I don't claim
> that the attached patch will work, but it should be a good starting point.
> Hamish
Thanks (both you Hamish and Glynn)!
The --with-cairo configure option seems to work well (I tried it after
Glynn's update to use pkg-config).
It appears that assigning ownership to myself means that the update
message doesn't get sent to the list.
It would be nice if that can be changed; IMHO, all tracker messages
should be copied to the list.
For completeness, below is a small patch to update the Cairo monitor
documentation to reflect this change, that perhaps someone can apply?
I've made the changes.
I couldn't apply the patch directly, due to reformatting by your mail
client. Ideally, patches should be sent as attachments rather than
pasted into the message body.
