[GRASS-dev] [GRASS GIS] #3313: "None" for no color in the color rules syntax
Reporter: NikosA | Owner: grass-dev@…
Priority: normal | Milestone: 7.2.2
Component: Vector | Version: unspecified
Keywords: d.vect, rgb, none, no color | CPU: Unspecified
Platform: Unspecified |
Currently the color rules syntax does not feature a "None" or "none" or,
perhaps, a "NULL" value to mean no color.
In example,
d.vect hexagons rgb=rgb_column
won't work for if the rgb_column contains "none", "None" or "NULL". A
warning reports the afore mentioned as invalid color rules.
Perhaps it would be meaningful to support them or one of them.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3313&gt;
