#3409: d.what.vect JSON issue with OSM data
Reporter: neteler | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.2.2
Component: Display | Version: svn-releasebranch72
Keywords: d.what.vect, v.what | CPU: x86-64
Platform: Linux |
I have imported successfully an OSM pbf file, can display it but not
query:
ScriptError(_("v.what output is not valid JSON format:
(screenshot attached since the error cannot be copy-pasted, no text
selection possible)
Here an example for v.what output not parsable by d.what.vect (note: this
is not exactly the same position as in the error msg screenshot):
v.what roads coordinates=13.3926375553,52.5548668929 -a
East: 13:23:33.495199E
North: 52:33:17.520814N
Map: roads
Mapset: osm
Type: Point
Layer: 1
Category: 34721
Resolution: | Keywords: d.what.vect, v.what
CPU: x86-64 | Platform: Linux
Comment (by mmetz):
Replying to [ticket:3409 neteler]:
query:
this is not exactly the same position as in the error msg screenshot):
> Map: roads
> Mapset: osm
> Type: Point
> Layer: 1
> Category: 34721
> Driver: sqlite
> Database: /home/mneteler/grassdata/latlong_wgs84/osm/sqlite/sqlite.db
> Table: roads_1
> Key column: cat
> cat : 34721
> osm_id : 631984925
> name :
> barrier :
> highway :
> ref :
> address :
> is_in :
> place :
> man_made :
> other_tags : "addr:city"=>"Berlin","addr:street"=>"Bornholmer
Straße","addr:suburb"=>"Gesundbrunnen","addr:country"=>"DE","addr:postcode"=>"13359","addr:housenumber"=>"50"
> Some more "escaping" might be needed here?
Alternatively you can use a osmconf.ini file
[http://gdal.org/drv_osm.html\] to 1) avoid the creation of the other_tags
field, 2) select some of the OSM keys summarized in the other_tags field.
