#3423: UnicodeDecodeError in r.category in wxGUI when category labels contain
special characters
Reporter: mlennert | Owner: grass-dev@…
Type: defect | Status: new
Priority: normal | Milestone: 7.4.0
Component: wxGUI | Version: svn-trunk
Keywords: r.category encoding | CPU: Unspecified
Platform: Unspecified |
I have a map with the following categories:
> r.category liege_ucl
0
10 eau
15 sol nu
20 bâti
21 route
30 terre labourée
35 herbage non naturel
40 zone ouverte (semi)naturelle 1
45 zone ouverte (semi)naturelle 2
48 zone ouverte (semi)naturelle 3
50 résineux
55 feuillus
In the GUI, r.category gives:
r.category map=liege_ucl@RW
0
10 eau
15 sol nu
21 route
55 feuillus
i.e. all categories with special characters in the labels are just
ignored.
The traceback in the Console window:
File
"/data/home/mlennert/SRC/GRASS/grass_trunk/dist.x86_64-pc-
linux-gnu/gui/wxpython/gui_core/goutput.py", line 472, in
OnCmdOutput
self.cmdOutput.AddStyledMessage(message, type)
File
linux-gnu/gui/wxpython/gui_core/goutput.py", line 771, in
AddStyledMessage
self.AddTextWrapped(message, wrap=None)
File
linux-gnu/gui/wxpython/gui_core/goutput.py", line 722, in
AddTextWrapped
self.AddText(txt)
File "/usr/lib/python2.7/dist-
packages/wx-3.0-gtk2/wx/stc.py", line 2041, in AddText
return _stc.StyledTextCtrl_AddText(*args, **kwargs)
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 4: ordinal
not in range(128)
File
OnCmdOutput
File
AddStyledMessage
File
AddTextWrapped
self.AddText(txt)
UnicodeDecodeError
'ascii' codec can't decode byte 0xc3 in position 15: ordinal
not in range(128)
File
OnCmdOutput
File
AddStyledMessage
File
AddTextWrapped
self.AddText(txt)
UnicodeDecodeError
not in range(128)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3423>
