Is it possible to adjust the trac config so it looks back 3 days instead
of 30? We have enough activity that 30 days is a lot of commits. It slows
down the page download considerably, old news is uninteresting, you can
easily manually adjust it if you want to look longer, and I would guess is
a burden on the server as well.
the current timeline.htm is 176k. If I set the timeframe to 3 days it
reduces to 20k.
paying by the mb at the far end of a wet piece of string,
Frank wrote:
> Hamish,
> I have tentatively changed the "default_daysback" setting in
/var/www/trac/grass/conf/trac.ini to
> 3 and restarted apache. If the group agrees on a different setting let
me, or another SAC admin
> know and it can be altered. I agree 30 days produced too much material
for GRASS.
I am fine with that since the user can manually change to something else.
