[GRASS-dev] [GRASS GIS] #3488: v.in.ogr mangeling of column names when imporing OSM geojson extracts
Reporter: alice | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone: 7.4.1
Component: Vector | Version: svn-releasebranch74
Keywords: v.in.ogr | CPU: All
Platform: Linux |
I tried to import geojson extracts from http://overpass-turbo.eu/ with the
query `highway=* and type:way` for the area of Bonn. When importing it
with v.in.ogr appeared:
Error in sqlite3_prepare():
duplicate column name: sloped_curb_end
This happens whenever changing the column names from name:name to
name_name, and whenever name_name is already existing in the dataset, it
stops and gives an error.
It would be nice to find a different solution while changing : of the
initial column names, maybe with whenever changing a : into _ adding a 1
at the end of the new name in order to prevent the creation of duplicates.
Geojson file attached.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488&gt;
Resolution: | Keywords: v.in.ogr
       CPU: All | Platform: Linux
Changes (by alice):
* Attachment "bonn_streets_OSM _EPSG4326.zip" added.
Geojson sample data to reproduce error
      Type: defect | Status: closed
Resolution: fixed | Keywords: v.in.ogr
Changes (by mmetz):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"72209" 72209]:
#!CommitTicketReference repository="" revision="72209"
v.in.ogr: fix duplicate column names (fixes #3488)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488#comment:1&gt;
      Type: defect | Status: reopened
Changes (by mmetz):
* status: closed => reopened
* resolution: fixed =>
Comment:
Replying to [comment:1 mmetz]:
Re-opening because it is not yet fixed in relbr74
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488#comment:2&gt;
Changes (by neteler):
* status: reopened => closed
Comment:
In [changeset:"72215" 72215]:
#!CommitTicketReference repository="" revision="72215"
v.in.ogr: fix duplicate column names (trunk, r72209; fixes #3488)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488#comment:3&gt;
Comment (by mmetz):
Replying to [comment:3 neteler]:
Is it working for you now?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488#comment:4&gt;
Comment (by alice):
Perfect, it is working now! Thank you!
Ticket URL: <https://trac.osgeo.org/grass/ticket/3488#comment:5&gt;
