[GRASS-dev] [GRASS GIS] #3494: r.thin crashes after 84 passes
Reporter: pitstop | Owner: grass-dev@…
     Type: defect | Status: new
Priority: normal | Milestone:
Component: Raster | Version: 7.4.0
Keywords: | CPU: Unspecified
Platform: MSWindows 7 |
Hi Community,
I wanted to use r.thin on a raster map before r.to.vect on the result but
r.thin crashes after 84 passes every time. Smaller number of iterations
run without any problems. I was able to reproduce the error by using
r.thin on the elevation.dem from the Spearfish data set. The following
error is printed to the console.
Exception in thread Thread-25:
   File "C:\OSGEO4~1\apps\Python27\lib\threading.py", line
808, in __bootstrap_inner
     self.run()
   File "C:\OSGEO4~1\apps\grass\grass-7.4.0\gui\wxpython\core
\gconsole.py", line 156, in run
     self.resultQ.put((requestId, self.requestCmd.run()))
\gcmd.py", line 614, in run
     self._redirect_stream()
\gcmd.py", line 643, in _redirect_stream
     self.stderr.write(line)
\gconsole.py", line 300, in write
     self.message += line.split(':', 1)[1].strip() + '\n'
IndexError: list index out of range
Any Ideas what might be going wrong?
The output of g.versoin -rge
version=7.4.0
date=2018
revision=r72154
build_date=2018-01-27
build_platform=x86_64-w64-mingw32
build_off_t_size=8
libgis_revision=70829
libgis_date="2017-04-04 09:43:02 +0200 (Tue, 04 Apr 2017) "
proj4=4.9.3
gdal=2.2.3
geos=3.5.0
sqlite=3.17.0
Stefan
Ticket URL: <https://trac.osgeo.org/grass/ticket/3494&gt;
Resolution: | Keywords:
       CPU: Unspecified | Platform: MSWindows 7
Comment (by mlennert):
Replying to [ticket:3494 pitstop]:
> Hi Community,
but r.thin crashes after 84 passes every time. Smaller number of
iterations run without any problems. I was able to reproduce the error by
using r.thin on the elevation.dem from the Spearfish data set.
While this should probably be handled more gracefully, could you explain
what you are trying to do with r.thin ? Why would you run r.thin on a DEM
? r.thin is meant to thin raster lines (represented by some form of
discrete pixel values) to single pixel width so as to make their
vectorisation possible. Running it on a raster map with a continuous
variable doesn't make sense in my understanding.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3494#comment:1&gt;
Component: wxGUI | Version: 7.4.0
Changes (by mmetz):
* component: Raster => wxGUI
Comment:
Replying to [comment:1 mlennert]:
> > Hi Community,
On the OS command line
g.region -p rast=elevation.dem
r.thin in=elevation.dem out=elevation.dem.thin it=1000
finishes successfully after 229 passes.
Apparently the problem is that the gui can't handle the messages produced
by r.thin, i.e. the gui crashes, not r.thin.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3494#comment:2&gt;
#3494: r.thin crashes the wxGUI after 84 passes
  Priority: normal | Milestone: 7.4.5
Component: wxGUI | Version: svn-releasebranch74
Resolution: | Keywords: r.thin
Changes (by neteler):
* keywords: => r.thin
* version: 7.4.0 => svn-releasebranch74
* milestone: 7.2.4 => 7.4.5
Ticket URL: <https://trac.osgeo.org/grass/ticket/3494#comment:4&gt;
