[GRASS-dev] [GRASS GIS] #351: Error with r.drain with gdal 1.5.2 and 1.6.0
Reporter: lucacasagrande | Owner: grass-dev@lists.osgeo.org
     Type: defect | Status: new
Priority: minor | Milestone: 6.4.0
Component: Raster | Version: svn-trunk
Keywords: r.drain raster | Platform: Linux
      Cpu: x86-64 |
Hello everybody,
I have got some troubles building grass 6.4.0 with gdal 1.5.2 and gdal
1.6.0.
This is the error:
root@doktoreas-laptop:/usr/src/grass_dev64/raster/r.drain# make
gcc -I/usr/src/grass_dev64/dist.x86_64-unknown-linux-gnu/include
-I/usr/local/lib -g -O2 -I/usr/local/lib -I/usr/local/include
-DPACKAGE=\""grassmods"\" -I/usr/src/grass_dev64/dist.x86_64-unknown-
linux-gnu/include -o OBJ.x86_64-unknown-linux-gnu/main.o -c main.c
main.c: In function ‘main’:
main.c:309: warning: ignoring return value of ‘write’, declared with
attribute warn_unused_result
main.c:402: warning: ignoring return value of ‘read’, declared with
main.c: In function ‘drain’:
main.c:473: warning: ignoring return value of ‘read’, declared with
In function ‘open’,
     inlined from ‘main’ at main.c:303:
/usr/include/bits/fcntl2.h:51: error: call to ‘__open_missing_mode’
declared with attribute error: open with O_CREAT in second argument needs
3 arguments
In function ‘open’,
     inlined from ‘main’ at main.c:304:
3 arguments
make: *** [OBJ.x86_64-unknown-linux-gnu/main.o] Error 1
Ticket URL: <http://trac.osgeo.org/grass/ticket/351&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: r.drain raster
  Platform: Linux | Cpu: x86-64
Changes (by neteler):
  * status: new => closed
  * resolution: => fixed
Comment:
Already fixed in r34110 (also for 6.3.svn and 7.svn).
Ticket URL: <http://trac.osgeo.org/grass/ticket/351#comment:1&gt;
