#3519: GUI: show computational region extent by default
Reporter: martinl | Owner: grass-dev@…
Type: task | Status: new
Priority: normal | Milestone: 7.6.0
Component: wxGUI | Version: unspecified
Resolution: | Keywords: map display, comp extent
Comment (by martinl):
In [changeset:"72381" 72381]:
#!CommitTicketReference repository="" revision="72381"
wxGUI: add settings to show comp. region extent, see #3519
First step implemented in r72381. New setting to enable showing
computational extent added, see GUI preferences -> Map Display -> Show
computational region extent, see attachment:mapdisp-settings-
In [changeset:"72436" 72436]:
#!CommitTicketReference repository="" revision="72436"
wxGUI: set up default map display properties when new display is open
(merge r72379, r72381 from trunk)
