[GRASS-dev] [GRASS GIS] #3621: Cannot create map frame in cartographic composer
Reporter: cmbarton | Owner: grass-dev@…
     Type: defect | Status: new
Priority: blocker | Milestone: 7.4.2
Component: wxGUI | Version: unspecified
Keywords: map frame, cartographic composer | CPU: Unspecified
Platform: Unspecified |
Because the button to save a display to an image file is also broken,
there is no way to export a map from GRASS. So I'm elevating both bug
reports to blockers. This is broken in at least v. 7.4.1 and up.
I can draw a dotted line rectangle but it does not create a map frame. So
nothing else works in the composer.
Here is the error:
   File "/Applications/GRASS-7.5.app/Contents/Resources/gui/w
xpython/psmap/frame.py", line 1463, in MouseActions
self.OnLeftUp(event)
xpython/psmap/frame.py", line 1611, in OnLeftUp
settings=self.instruction, rect=rectPaper)
xpython/psmap/dialogs.py", line 772, in __init__
notebook=False)
xpython/psmap/dialogs.py", line 846, in __init__
self._layout()
xpython/psmap/dialogs.py", line 1122, in _layout
convertRGB(self.mapFrameDict['color']))
xpython/psmap/utils.py", line 181, in convertRGB
color = wx.Colour(*color)
TypeError
Colour(): arguments did not match any overloaded call:
   overload 1: too many arguments
   overload 2: argument 1 has unexpected type 'float'
   overload 3: argument 1 has unexpected type 'float'
   overload 4: argument 1 has unexpected type 'float'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621&gt;
Resolution: | Keywords: map frame, cartographic composer
Old description:
Here is the error:
notebook=False)
self._layout()
TypeError
New description:
Here is the error:
notebook=False)
self._layout()
TypeError
Comment (by neteler):
(properly formatting error report)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:1&gt;
Comment (by annakrat):
In [changeset:"73404" 73404]:
#!CommitTicketReference repository="" revision="73404"
wxGUI: fix for wxPython 4, see #3621
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:2&gt;
Please test in trunk, I will then backport it.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:3&gt;
  Priority: critical | Milestone: 7.4.2
Changes (by martinl):
* priority: blocker => critical
Comment:
@Michael, can you test it please sooner that later? RC1 is planned in the
next days. BTW, priority blocker is disputable since it's related to one
wxGUI component and wxPython4. I took liberty to decrease priority to
avoid blocking release.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:4&gt;
Comment (by cmbarton):
If I get my proposal in early enough I’ll test today. Otherwise tomorrow.
Thanks again
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:5&gt;
I just tested this in trunk and it works. Thanks much. Is this backported
so we can close the ticket?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:6&gt;
In [changeset:"73418" 73418]:
#!CommitTicketReference repository="" revision="73418"
wxGUI: fix for wxPython 4, see #3621 (merge from trunk, r73404)
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:7&gt;
In [changeset:"73419" 73419]:
#!CommitTicketReference repository="" revision="73419"
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:8&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: map frame, cartographic composer
* status: new => closed
* resolution: => fixed
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:9&gt;
      Type: defect | Status: reopened
Changes (by cmbarton):
* status: closed => reopened
* resolution: fixed =>
Comment:
We need to reopen this. I just did a checkout and compile of 7.6RB. The
rubber band part of the map frame now works to open the dialog where you
can pick a map to display. But when you click OK, it generates an error.
   File "/Applications/GRASS-7.6.app/Contents/Resources/gui/w
xpython/psmap/dialogs.py", line 446, in OnOK
ok = self.OnApply(event)
xpython/psmap/dialogs.py", line 791, in OnApply
self.parent.DialogDataChanged(id=self.id[0])
xpython/psmap/frame.py", line 1120, in DialogDataChanged
bb=rectCanvas)
xpython/psmap/frame.py", line 2194, in Draw
w, h, lh = dc.GetMultiLineTextExtent(text)
ValueError
need more than 2 values to unpack
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:10&gt;
Try 73434.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:11&gt;
Thanks. I'll try to squeeze it in tomorrow. Otherwise, Friday.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:12&gt;
The issue with setting the map frame is now fixed. I was able to give a
full test and ran into 2 other issues which I'll mention here. One is
already reported and a serious problem. The other is less so but makes the
cartographic composer unusable for most purposes. We can keep this open
for these cartographic composer issues or move them to another ticket
because they are different from the map frame per se.
Issue 1: Cannot select point symbols. This also affects the vector
display, which is very serious. Here is the error when you click on the
button to select a symbol.
xpython/psmap/dialogs.py", line 3149, in OnSymbolSelection
currentSymbol=self.symbolName.GetLabel())
xpython/gui_core/dialogs.py", line 2067, in __init__
self._layout()
xpython/gui_core/dialogs.py", line 2073, in _layout
fgSizer = wx.FlexGridSizer(rows=2, vgap=5, hgap=5)
TypeError
FlexGridSizer(): arguments did not match any overloaded
call:
   overload 1: 'hgap' is not a valid keyword argument
   overload 2: 'hgap' is not a valid keyword argument
   overload 3: 'hgap' is not a valid keyword argument
   overload 4: 'hgap' is not a valid keyword argument
Issue 2. You cannot add a scale bar. All the other items can be added.
Just not a scale bar. Here is the error:
xpython/psmap/frame.py", line 686, in OnAddScalebar
dlg = ScalebarDialog(self, id=id, settings=self.instruction)
xpython/psmap/dialogs.py", line 4776, in __init__
self.panel = self._scalebarPanel()
xpython/psmap/dialogs.py", line 4947, in _scalebarPanel
self.sbCombo = wx.combo.BitmapComboBox(panel,
style=wx.CB_READONLY)
AttributeError
'module' object has no attribute 'combo'
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:13&gt;
A bit more info. These 2 issues (symbols for points and scale bar) affect
the cartographic composer in trunk too.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:14&gt;
Should be fixed now, also backported to 76 and 74.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:15&gt;
I'll test on Monday. Thanks much.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:16&gt;
Everything is fixed in trunk. But not in 7.4. I have not tried 7.6
I updated 7.4 release branch and tested. Am I looking in the right place?
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:17&gt;
I hope now it should work everywhere (r73479).
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:18&gt;
Thanks for all the work on this. I’ll test tomorrow.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3621#comment:19&gt;
